So the situation is this. I own Hercules DJ Console MK4 and Virtual DJ Pro. When I press TALKOVER and SOURCE buttons at the same time, I want to double the loop's length (loop 200%). I have already mapped "loop 50%" function to bare SOURCE button.
Now, no matter what I do, when I press TALKOVER and SOURCE buttons at the same time, "loop 50%" happens. So this thing doesn't count the press of a TALKOVER button for some reason
I don't know if it's even possible to map this thing to do something when I press two buttons at the same time. But if it is possible, can anyone tell me how?
geposted Sun 15 Apr 12 @ 10:31 am
I sort of figured out the answer. I need to edit the definition file, which is unfortunately not available for natively recognized MIDI-things like MK4.
Maybe I'll just use regular keyboard instead. Altough if someone still knows how to help, I'm more than happy.
geposted Sun 15 Apr 12 @ 12:12 pm
Please register your Pro serial number on the page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html - Your MK4 entitles you to a discount.
The TALKOVER button on the MK4 may be a hardware switch that doesn't send a MIDI message, so can't be mapped. The controller definitions that are built into the software are not available separately and cannot be accessed. You could perhaps use another button instead or keyboard shortcuts.
geposted Mon 16 Apr 12 @ 7:29 am
