Forum: Old versions
Topic: Activate sound effect and no sound?
Hi, I've been having this problem for a while and am not sure what is causing it.
Sometimes when I activate an effect (namely the Filters and Flanger) I get no sound output on that deck and the only way I can get sound back is by disabling the effect. It is an intermittent problem and I never know when its going to occur. I think it may have something to do with when the deck 1 and deck 2 buttons appear beside where you active the effect in the effects window. I haven't used effects much before now so am unfamiliar with what these do.
Any help on how to avoid or get rid of this problem would be much appreciated!
Thanks
geposted Mon 16 Apr 12 @ 10:49 am
