My DN-MC6000 is not starting, only lights in standby mode. I've tried to activate the automatic standby mode "on" and then hit restart, then switched it into "off" and turned it on and off and nothing happened. Could someone help me, please! Thanks!
geposted Thu 19 Apr 12 @ 3:45 am
You may have accidentally change the MIDI channels that it operates on.
Press SHIFT+BROWSER to switch it back to the default.
Please see http://www.virtualdj.com/wiki/DN-MC6000.html for further information and troubleshooting.
geposted Thu 19 Apr 12 @ 7:16 pm
My Denon dn-mc6000 connected to power and won't turn on only standby light on. Restarted and still no fix? Please help?
geposted Sat 28 May 16 @ 4:57 am
Did you try resetting the MIDI channel (message above yours)?
Have you contacted Denon support?
geposted Sat 28 May 16 @ 7:48 am
This can also happen if one of the ribbon cables to the main board have come loose or aren't contacting properly. Seen this a couple of times while repairing buttons on my friends controllers.
geposted Sat 28 May 16 @ 11:17 am
im haveing kind of the same problem all the lights work but my computer will not find the contoller when i plug it in and the standby light stays on i tryed the shift+browse did nothing
geposted Sun 05 Feb 17 @ 3:45 am
Is the standby switch in the front of the controller on?
geposted Sat 18 Feb 17 @ 7:02 am
