I just started using this program, I have it set up on my MacBook pro using Maya 44 and Rane timecode vinyl to use as time code on my tech's. I have finally got it to trigger the musin using the time code vinyl but it doesn't keep the pitch, not will the sync function work. Also, when I cue it up it will show the start at the beginning, but then when I start it it will start half way in the song. Not sure what I messed with that has caused this, but any help would be appreciated. If someone had a screen shot,of their settings that were working that would be a great help!
Thanks!
Thanks!
geposted Thu 03 May 12 @ 9:06 pm
No one can help. I just need the default settings for VDJ.. PLease help..
geposted Thu 10 May 12 @ 4:57 pm
the mac forum is not a very active forum, i would try youtube to see if someone has made a video on the subject.
good luck.
also i think there is a button you can click to go back to factory settings in the software
config>mappers>click on button at bottom that looks like it has a small CD in it this will revert the mapper back to factory settings
good luck.
geposted Fri 11 May 12 @ 11:37 am
Please ensure that your timecode is configured correctly - See our FAQ pages on this subject: http://www.virtualdj.com/wiki/How%20do%20I%20configure%20my%20timecode.html
Also, make sure that you have the latest version of the software installed. Please register your Pro serial number on the page http://www.virtualdj.com/users/edit.html and download the latest version from http://www.virtualdj.com/download/updates.html
If you are trying it out in Home FREE (Allows 10 minutes at a time), please download the latest version from: http://www.virtualdj.com/download/free.html
NOTE: You will need to purchase the full VirtaulDJ Professional to be able to use timecode for more than 10 minutes: http://www.virtualdj.com/buy/index.html
geposted Fri 11 May 12 @ 11:59 am
I have tried to set the time code settings, but its still is quirky, it has worked the smoothest it has ever tonight, but its hit or miss. I can never get to 100% on the quality on the timecode. Is this normal?
geposted Tue 15 May 12 @ 8:08 pm
Are you using a legit version?
Only reason I am asking is because you have not registered your license.
I have found that people are more apt to assist when they know you are a legal user.
Register your license and I bet you get better replies.
geposted Thu 17 May 12 @ 8:47 am
