prejudice could have the mapping of the new numark 4trak?
geposted Sat 16 Mar 13 @ 4:27 am
Thank you very much!
geposted Sat 16 Mar 13 @ 4:35 am
if you need/want anyone else to test it out I have a brand new 4trak thats willing and ready
geposted Tue 21 May 13 @ 12:06 am
Hello,
as you need our Professional Full version to use my mapping - if you own a license just register it and visit this Thread again. The link is only visible to registered Professional Full verision users.
Greets Heiko
Greets Heiko
geposted Tue 21 May 13 @ 12:49 am
Hi guys,
woud be nice if one of you could test all features of the mapper and the analogue mixer part.
As i send the device back to Numark i can only test and make changes while the next week.
Greets, Heiko
Greets, Heiko
geposted Fri 24 May 13 @ 12:58 pm
I get my 4trak today ( i hope) so i test it in the wekend and let you know.
geposted Wed 29 May 13 @ 2:07 am
Hi I just got the Numark 4Trak 2 days ago and would like help mapping it for VDJ. Can anyone help!?!
geposted Mon 03 Jun 13 @ 5:44 pm
Hi,
you find the download link a few postings above.
Greets, Heiko
Greets, Heiko
geposted Tue 04 Jun 13 @ 12:07 am
jakovski wrote :
Version 1.2
New Link below - Version 1.3
<removed the description>
- implemented switches (input selector) for Analogue/PC and Analogue/MIC
how do i get the mapping for the 4trak mate?
geposted Tue 11 Jun 13 @ 2:22 pm
The download link is in the posting directely above yours.
geposted Tue 11 Jun 13 @ 2:30 pm
Hey Heiko, get custom map! It's working quite well for me. A few things I found, maybe just me. The headphones knobs don't work, adjusting them on screen will work. That's really my only concern. Thanks!
geposted Thu 13 Jun 13 @ 5:47 pm
Heaphone Volume and CUE/MIX are Hardware faders - so if you are using the Audio device of the 4Trak they have to work !
Setup them in the AUDIO Panel of VDJ as follow:
NONE
HEADPHONE
ASIO (4Trak)
That's it. If you are using a seperate Soundcard then you are right. In that case just add the 2 mapping commands to the mapper to control CUE/MIX and VOLUME. But in my eyes the Soundcard is not that bad so you should be able to use the internal ;-)
Greets, Heiko
NONE
HEADPHONE
ASIO (4Trak)
Greets, Heiko
geposted Fri 14 Jun 13 @ 3:15 am
jakovski wrote :
Version 1.3
<LINK REMOVED>
<LINK REMOVED>
- fixed SET MASTER led
- fixed FX A/B led's on each channel
- fixed RECORD led
- fixed CRUISE led
Just wanted to say that I've downloaded your latest map & tried it over the weekend at a party; IT WORKED GREAT!!!! Thanks a lot!!! I've attempted to create one on my own but ran into some problems with the jog wheel. This map utilizes practically all of the 4Traks features including LED lights!!! I only had 1 gliche in the beginning where VirtualDJ did not recognize the main part of the 4Trak as being connected to my computer, just the FX portion. That has since been fixed as I had to update my drivers. Otherwise, no issues to report at all! Thanks again!
geposted Wed 19 Jun 13 @ 2:27 pm
how do i get download the mapping for the 4trak, please ?
geposted Wed 19 Jun 13 @ 4:08 pm
You need to register you coy of Vrtual DJ Professional Full in order to download it. The link is shown when you are logged in a s Pro Full user a few postings above this.
Greets, Heiko
Greets, Heiko
geposted Thu 20 Jun 13 @ 12:00 am
OK I have VDJ PRO and it is registered but I can not see any link to get the mapper for the 4trak. PLS help!
geposted Fri 21 Jun 13 @ 4:17 pm
Ok,
just go back 1 page in this Thread - i posted the last update at: 06 Jun 13 @ 4:01 pm
A bit more in the past you will find a list of all features within the mapper.
I will upload it as soon as i fixed the MAC problem i actually have with it.
Greets, Heiko
Greets, Heiko
geposted Sat 22 Jun 13 @ 4:10 am
Well I found the link for 4trak. How do you instal? I have Windows 7 machine and will this work with it?
geposted Thu 27 Jun 13 @ 8:31 am
Just read the thread! It works great. Keep up the good work. Thank you.
geposted Thu 27 Jun 13 @ 9:34 am
I have a issue. When I load a track either by the 4trak controller or my mouse, then the opposite deck or the track playing stops. I have to switch with the tab key in order to get sound back on the playing track. Is there something that I am doing wrong or is there something not properly set in setup?
geposted Fri 28 Jun 13 @ 9:19 am
