Bought my Mixtrack Quad and VDJ won't open on my MacBook. Tried copying the VirtualDJ to every library folder I could possible find (another user, shared, system) and it still won't work. I was suspecting the OS X Beta version I'm running but my iMac is running one too and it opens just fine...
I can't believe there's no way to solve this. Tried everything written here.
geposted Sun 18 Jan 15 @ 9:48 am
Try to install the older Version 7.4 first and then the 7.4.2 worked for me!!!
geposted Fri 06 Mar 15 @ 9:39 am
how to apply the lattest skin in my vdj, like piooneer skin.. pls help me
geposted Fri 06 Mar 15 @ 12:57 pm
I have tried clean installs ect. as suggested in the forum, I decided that I will try installing it from my disk and that worked!
geposted Sun 08 Mar 15 @ 9:09 pm
IT WORKS!!!!
In new installations of VirtualDJ v7.0.3 and above, the VirtualDJ home folder which contains your database, playlists, skins, effects, etc. is now located in the Library folder to meet the requirements of Apple Store.
However, Apple have decided to hide the Library folder to prevent accidental modification by users.
Methods to show the Library:
Access via the Finder menu
The Finder menu has some extra and hidden entries.
Open a Finder window, click on the "Go" menu and press the ALT key to reveal the Library.
Access with a keystroke
In any Finder window (on the Desktop as well), you just need to press CMD+SHIFT+G and then type in the following: ~/Library/
Completely unhide the Library (Expert users only)
Run this command to reveal the Library: chflags nohidden ~/Library/
If you want to hide the Library again : chflags hidden ~/Library/
geposted Mon 25 May 15 @ 3:11 pm
took me four hours to figure out.
First you need to install virtual dj le (vdj) then when prompted to put serial key in just skip by closing the window vdj will open in demo mode next go to config top right then advanced options click on try 20 day pro version then close vdj.
re open vdj and you will be prompted once again to put in serial number in put it in then you should be able to open vdj without the error coming up,
will let you know how it goes in 20 days lol
but so far its working good
thanks sound and division for your shet customers service
geposted Wed 30 Dec 15 @ 4:37 am
Worked For Me!!!!!
geposted Fri 01 Apr 16 @ 1:30 am
thanks for letting us know
geposted Thu 12 May 16 @ 9:43 pm
It worked for me too but suddenly stopped worked after 20 days... Any help? Impossible to get back to a workable version...
geposted Wed 01 Jun 16 @ 6:52 pm
So, is this how it ends, people unfortunate enough to have the presenting problem just twist in the wind?
geposted Fri 23 Sep 16 @ 10:07 pm
Have same problem.
geposted Fri 10 Mar 17 @ 7:18 am
You have to extract the skin first.
https://www.virtualdj.com/forums/210043/VirtualDJ_8_2_Technical_Support/Default_skin.html
geposted Fri 10 Mar 17 @ 9:08 am
I have the same problem here and I can't understand how to fix it!
geposted Sun 12 Nov 17 @ 2:01 am
If you are running VirtualDJ LE with your WeGO, then probably looks for the tailored WeGO skin. Try to install this .. http://www.virtualdj.com/addons/15359/Pioneer_DDJ_WeGO.html
geposted Sun 12 Nov 17 @ 2:09 pm
dudewalker wrote :
I've tried to install VD7 into my PC.
Everything goes smoothly until I I receive this error.
"Cannot find the skin file in Virtual DJ document"
Yet, when I go to My Documents, I can see the files in the VrtualDJ folder.
Any ideas?
Any ideas?
geposted Tue 04 Apr 23 @ 1:54 am
Any ideas?
Any ideas?
geposted Tue 04 Apr 23 @ 2:06 am
