I have two different rigs for two types of events, and I would like to use the same pc. If I use the hd4500 in one setup, and dac3+usb audio in the second rig, how much of a pain will that be to configure between shows? Sometimes I will be walking to an adjacent room for the next show, so it needs to be pretty quick.
Thanks.
Thanks.
geposted Wed 30 May 12 @ 1:23 am
yes you can use multiple controllers no problem, but you cant use multiple mappings for the same controller atleast until version 8 as shown in the alpha version. If you need different soundcards you can use sbdj's "profile switcher" tool to change the sound source settings.
geposted Wed 30 May 12 @ 1:38 am
It can do multiple mappings too :)
geposted Wed 30 May 12 @ 8:11 am
You guys are awesome, you thought of everything. I can't believe I bought this a year ago and am just now getting around to migrating from pcdj fx. The software is on another level.
Thanks.
Thanks.
geposted Wed 30 May 12 @ 2:06 pm
if you want something quicker and dont mind doing some work on the mappers, you can have the mapping change depending on what other controllers are present.
geposted Fri 01 Jun 12 @ 10:27 pm
