Forum: Old versions
Topic: VDJ 7 Pro: Recording Both Channels
dugTRIOPRO InfinityMember since 2011
So I have been working on VDJ 7 for a while and have been unable to fix only one problem:
When I am recording within VDJ, my crossfader works properly while the 2 tracks I am mashing play. The issue is that when listening to the recorded material, both channels are in it, regardless of where (and when) I moved my crossfader. I am using VDJ Pro 7 attached to an American Audio VMS4. I need somebody to tell me what I have done wrong and how do I fix it. Thanks in advance.
geposted Fri 01 Jun 12 @ 3:09 am
geposted Fri 01 Jun 12 @ 4:17 am
I have done this, and it didn't work. It actually wouldn't even play through my speakers or headphones. Any other ideas?
geposted Fri 22 Jun 12 @ 2:32 pm
Well that's the correct way to do it.
If it's not working, you must have something set up incorrectly.
Without you providing more detail, there's nothing more I can suggest.
geposted Sat 23 Jun 12 @ 11:16 am
