Forum: Old versions
Topic: VDJ Now crashing frequently (OSX Lion)
pskeensPRO InfinityMember since 2010
I have used my MB Pro 13 and VDJ ever since I started using VDJ about a 1 1/2 years ago. I used it because it never crashed and was stable. I was away for a while and didn't get to use my equipment during this time. I started everything back up last weekend and started to practice again and mix some tunes. In about 5 hours of mixing VDJ locked up and force closed about 5 or 6 times. Is anyone else experiencing issues now?
I updated ITCH to the latest version, Updated NS6 Firmware, Updated VDJ 7 Pro to latest update. Everything has been updated and this is the only program that is crashing on my MB Pro. Any thoughts or help is appreciated. Thanks
geposted Wed 06 Jun 12 @ 8:26 pm
Crash reports would be helpful.
Make sure you aren't using the dsp effects as they have been withdrawn, and I would recommend disabling cover art in the VDJ browser too.
geposted Wed 06 Jun 12 @ 8:35 pm
I think its the same issue as another has in this forum. I am going to try removing the Effects (Namely Reverb) one by one to see if this helps.
geposted Wed 06 Jun 12 @ 9:12 pm
OK well I will lock this then to keep the discussion in one place.
geposted Wed 06 Jun 12 @ 10:19 pm
