Hi
I am using the pioneer ergo skin, but would like to add under the cues 1,2,3,4 a counter timer so i can see in seconds how much time i have left to the next cue or gone from the previous cue.
I would appreciate this as the other skin i used had this but was only 2 decks and want to use this as it seems very good but would like this feature and maybe even a beatlock button for each deck.
Any help would be appreciated.
Thanks
Thanks
geposted Fri 08 Jun 12 @ 11:39 am
you just need to fill in the blanks. to get the "size and pos" use either jeremk's skin creator or paint should be okay just a little harder to read
<textzone deck="#" format="%Ptocue#">
<size width="" height=""/> how big the text box will be
<pos x="" y="" /> where the textbox is positioned on screen, x is horizontal axis, y is vertical
<text size="" font="" color="" align=""/>
</textzone>
eg
<textzone deck="1" format="%Ptocue1">
<size width="50" height="20"/>
<pos x="20" y="200" />
<text size="14" font="arial" color="#088605" align="left"/>
</textzone>
the color of the text is in hex or html, you can find colors online or in a decent picture editor
if you paste the example in your skin file you will see a textzone with info for deck 1 cue 1, in the above green text
</textzone>
eg
</textzone>
geposted Fri 08 Jun 12 @ 12:27 pm
Thanks
I will have a go, just been really busy to try it out. Thanks for the help.
geposted Sun 01 Jul 12 @ 4:20 pm
Hi
Just tried it and it comes up with invalid skin file error line 6933 in the xml file.
Not sure why this is, i was just using wordpad to edit the xml file.
If you could help me out i would appreciate it.
thanks
ps i tried putting it near the begging and at the end both did not work.
thanks
geposted Sun 01 Jul 12 @ 4:43 pm
Just got it working just had to add one minor thing to a line.
<pos x="28" y="390" />
<text font="arial" size="12" color="#908f8d" weight="bold" align="left" format="%Ptocue1"/>
</textzone>
Thanks again could not have done it without you.
</textzone>
geposted Sun 01 Jul 12 @ 5:26 pm
The format part in the first line is actually ignored. The proper place to have the format is in the <text> line. So you may delete the first one.
geposted Mon 02 Jul 12 @ 1:11 pm
