Forum: Old versions
Topic: Please help! program crush!
T0M1xLE userMember since 2012
I got lenovo laptop.
and lastly i bought the new ddj ergo controler whitch came with his disc. (2 discs.. driver and program)
I installed it corectlly. but somethimes the program just quit automaticlly! with no reason.
first I thought that mabye my laptop is weak, but then I tried it in my own computer (Not laptop) and he is very strong. and is happend also!
what im trying to say is that I guess I have a problem with my controller\program and I think its more the program...
is just crash and dont show any errors like you exit it.
it happens like twice in every 4 hours....
what i need to do to get it right????
thank you very much!
geposted Tue 12 Jun 12 @ 7:20 am
If you are using the limited edition of VDJ, that could be the reason. On the other hand, what it does is disable your controller after 30 minutes (10 minutes?), and not shut down the actual software.
geposted Tue 12 Jun 12 @ 10:25 am
geposted Tue 12 Jun 12 @ 12:17 pm
virtualdj LE does not disable the controller, he just close himself mabye crush. :\
geposted Thu 14 Jun 12 @ 7:41 am
geposted Thu 14 Jun 12 @ 12:52 pm
