I recently downloaded the VDJHome version to see if I liked it with my NI Maschine. However I'm having difficulty seeing the maschine as an option for midi. I'm using macOSX and the maschine works fine with ableton. HELP!!!
geposted Sat 23 Jun 12 @ 2:42 pm
Maschine will never be native to VDJ as Native instruments don't want it to be, but if the device is midi compliant it should work in simple midi for the first 10 minutes, but a definition and mapper would need to be made to utilize the leds.
http://www.virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html
http://www.virtualdj.com/wiki/ControllerDefinitionMIDI.html
geposted Sat 23 Jun 12 @ 2:58 pm
The problem is it's not even recognizing the controller when I go to the Simple Wrapper. I've already tried going to that and adding a button but nothin happens when I try and assign it.
geposted Sat 23 Jun 12 @ 3:21 pm
I think if VDJ HOME FREE is running and it's been running for more than 10 minutes, it disable EXTERNAL devices. If so, you need to exit VDJ, then RUN IT AGAIN, and go to the config and do your mappings. If you reach 10 minutes, you need to EXIT VDJ, run it and basically YOU HAVE 10 MINUTES to do anything you want, then after that KABOOM...Ext.Devices will not work again until repeating EXITING, RUNNING etc...
geposted Sat 23 Jun 12 @ 4:30 pm
