hey guys anyone know were i can get a chopped air horn effect... i heard it many times dropped at clubs and it sounds awsome.... the only sample i have of it is on this mixtape... http://djchinaman.com/downloads/beat-up-that-beat/
download the mp3... go to 41:00 and you can hear it
been searching everywere and cant find it
geposted Sun 24 Jun 12 @ 12:27 am
you can just grab your typical horn effect grab an editing software or even on vdj apply an effect to it i do believe in vdj its a trans effect plugin and it will chop it up1-5-6 times before the end of the sample... or you can do it manually by simply playing the sample and moving the fader back and forth really fast thus creating a chopped trans like effect......... last thing you can do is just look for that effect online i am sure somebody in the world has uploaded it.... hoped i helped
geposted Sun 24 Jun 12 @ 9:33 am
You can also try the cut effect on it. I tried it and it works pretty good. It works well if you have a controller, that's mapped so you can adjust.
geposted Sun 24 Jun 12 @ 2:43 pm
