Forum: Old versions
Topic: Help:Numark Dj2go with usb soundcard?
swg323Home userMember since 2012
I want to get the Numark Dj2go but i have a concern, i dont know what usb sound card to use. I will eighther use virtual dj le or virtual dj home. Im trying not to spend over $100 in all.(including dj2go)Any suggestions for what sound card.(using it to cue) My main output would be going to an amplifier.
Thank you in advance
geposted Sun 08 Jul 12 @ 4:48 pm
geposted Sun 08 Jul 12 @ 6:40 pm
The problem with that workaround (it's not really a solution) is that he'll only get mono sound.
Most people these days prefer their music in stereo!
I'd suggest buying a pair of USB headphones, which can then be used to cue the songs (in stereo) whilst using the computer sound card for the main output.
geposted Sun 08 Jul 12 @ 7:26 pm
You so smart............(hope you heard that in STEREO)
geposted Sun 08 Jul 12 @ 8:54 pm
geposted Mon 09 Jul 12 @ 3:14 am
