since there is no dedicated filter button on the numark mixtrack, i would like to map it as follows:
when scratch A is lit, effect control knob 2 on side A can be used for filter
when scratch B is lit, effect control knob 2 on side B can be used for filter
and when they aren't lit, they are used as normal for the effects
if this mapping can't be done, is it possible to map the cue gain and cue mix knobs for filter A and filter B? i don't use those knobs anyway
thanks!
- supernatura1
thanks!
- supernatura1
geposted Tue 10 Jul 12 @ 5:29 pm
