Hello, I'm a long time searching for a good Dj Controller, he must under $ 900 have four channels,
usb input, usb audio interface, and you need to have on your laptop can close.
and you should be able to use him with Virtual Dj.
so if anyone knows a good Dj Controller ... ...
geposted Wed 18 Jul 12 @ 3:48 pm
Doesnt seem to be to helpful around here, so i will say for you to look into the Denon 6000 or the Pioneer DDT-1(If you like to scratch) There are a few reviews on youtube for 4 channel controllers. Hope this helps a little.
geposted Wed 18 Jul 12 @ 5:12 pm
imthedj2000 wrote :
Doesn't seem to be to helpful around here
Are you kidding? the question was asked less than three hours ago with many threads with the same question and information provided, this is honestly the most helpful dj software forum on the net.
Get a Reloop Terminal mix 4 or Vestax VCI-400, the differences are the soundcard in the vestax is higher quality, and if can be used as a 2 channel analog mixer and you can run timecodes through it, the reloop has pretty much the same amount of controls but the jogs are better and the pitch fader is longer... If you scratch and mix get the reloop, if you want to do controllerism tricks get the VCI. But everything on the market will work with VDJ Pro once mapped.
geposted Wed 18 Jul 12 @ 6:29 pm
hey! i don't know a dj but a friend of mine is in the same work they provide dj for parties and have professional dj's you can contact them if they can help you Good Luck!
geposted Wed 07 Nov 12 @ 11:22 pm
American Audio VMS 4.1
geposted Thu 08 Nov 12 @ 3:48 pm
yeah the vms4.1 is pretty good. just go to guitar center and look at the options there
geposted Sun 11 Nov 12 @ 12:39 pm
Hi does the reloop have touch sensitive jogs that will pause the track when held down ?
geposted Sun 09 Dec 12 @ 5:47 am
Yes, both Reloop Terminal Mix 4 and Terminal Mix 2 have touch-sensitive jogwheels.
geposted Sun 09 Dec 12 @ 11:53 am
what about ddj-ergo v???
geposted Fri 04 Jan 13 @ 7:17 pm
Yes, that has pressure sensitive jogwheels.
The majority of controllers released in the past few years have either touch or pressure sensitive jogwheels. But always check first on the manufacturer's website to confirm before purchasing.
geposted Sat 05 Jan 13 @ 2:38 pm
