Overall settings for use in Mp3Gain (target vol).....good all around, overall db level for rock, EDM, hip hop....etc.....I was guessing round 91-ish?.......thanks guys.....
geposted Thu 26 Jul 12 @ 2:13 am
First..sorry for my very bad englsih !!
With mp3gain you destroy the sound of the mp3- because the the programm make the gain in a middle gain, not complete anylyse , only a little "bit" ..
Let hte songs in the original gain, an click in VDJ " Autogain"...
so you have the mp3 original, and not "pimped" , so some songs you make it bad
try it with "Celine Dion - My heart will go on" her the original wenn it go the the loud refrain, an dann hear the "pimped" version with mp3 gain....its very bad....
Many greets from germany
Thomas
Thomas
geposted Thu 26 Jul 12 @ 3:55 am
93db I found to be best but with Vdj working on the sound engine and sound cards in the new controllers been better eg Rmx 2 etc you might be better at 91
geposted Thu 26 Jul 12 @ 6:35 am
Cd´s have alltimes other DB.
so, its better to keep the original db in the mp3.
Greets
Thomas
Greets
Thomas
geposted Thu 26 Jul 12 @ 7:00 am
I have used mp3gain at 94db for years now with VDJ auto gain disabled completely.
In my opinion it doesn't degrade the MP3, all it does is take an average gain then adjust the header.
Keith
Keith
geposted Thu 26 Jul 12 @ 7:23 am
Whatever happened to using your ears and adjusting the controls on the mixer?
:-O
:-O
geposted Thu 26 Jul 12 @ 10:21 am
:-O
:-O
Whatever happened to lighting fires with sticks and riding horses instead of having a car?
geposted Thu 26 Jul 12 @ 10:40 am
We got lazy.... lol
geposted Thu 26 Jul 12 @ 11:14 am
In the year 5555
Your arms hangin' limp at your sides
Your legs got nothin' to do
Some machine's doin' that for you
© Denny Zager, Rick Evans
geposted Thu 26 Jul 12 @ 11:43 am
I wouldn't use mp3gain. I've been told it re-levels the entire track which is not good like my man up top said. Some parts of the track aren't supposed to be raised. I for one use VDJ's auto gain and my ears. Plus it depends on your source. If the track is shit to begin with nothing is gonna help it.
My advice, use only trusted sources and use VDJ's auto / remember........ Good Luck
Huey
Huey
geposted Thu 26 Jul 12 @ 12:20 pm
It's all here: http://mp3gain.sourceforge.net/faq.php
Keith
Keith
geposted Thu 26 Jul 12 @ 12:23 pm
Yup I've read it but I still trust my ears over that program any day.......
Good Luck and Enjoy
Huey
Good Luck and Enjoy
Huey
geposted Thu 26 Jul 12 @ 12:33 pm
I ran my collection of Mp3's through the program last night. (Notice I said tracks not albums, you don't want the album completely leveled out
imo)......Results: MANY of my Mp3's were already clipping upon analysis some up to 100+ dbs......I reset them to 92 db target, and in turn the
software turned them all into a range of between 89 to 92db...No more clipping!!.....They all sound nice and bright in VDJ and even the ones
the dbs were lowered on sound better......The Bad Part: I think the resetting of the dbs somehow affects the compression of the waveform in
VDJ (or any waveform display)....the waveforms are there and correct, but a bit smaller and harder to Visually decipher where the vocals,
subtleties in the track are.....That is something that I hope can be adapted to, or the new VDJ 8 hopefully will be color coded a-la
Serato......Either way, if you don't like the results simply run the tracks again, anytime and it will undo any changes that were made.....
** Update, I ran all of em back through and hit "undo"......Just didnt sound right, VU meters were way off....I won't recommend.....Live and learn.. =D
geposted Thu 26 Jul 12 @ 3:20 pm
Please bear in mind that if you externally adjust the gain of a song that has already been previously analysed by VirtualDJ using a tool such as MP3gain, you will need to re-scan the song again in VirtualDJ to take the new adjustment into account, otherwise the adjustment as previously determined by VirtualDJ will no-longer be correct and the song will either be quieter or louder than it should be.
geposted Thu 26 Jul 12 @ 9:56 pm
Thank you for the heads up mysterious "Support Staff Teamer", but wouldn't that fact of "needing to reanalyze within VDJ" be negated if the tracks were not played in VDJ (there by updating the file) and were instead reverted to there "before" state (via undo in the option dropdown) in Mp3Gain?.........That is one of the few reasons I used this product, I could Undo and SEE the outcome of that undo...I would buy Atomix SOAP if it was sold,(maybe) but I was just trying a bit of experimentation and I reported my negative results......
** btw....tracks analyzed by MP3 Gain as "clipping" sound much better in their original "clipped state"......than "leveled"......not quit understanding that, but , I'll go with it.....
geposted Fri 27 Jul 12 @ 1:08 am
By the way you still need to gain every track when mixing to match the volumes but it's better for background music when your not there monitoring it.
geposted Fri 27 Jul 12 @ 4:42 am
Hopefully VDJ 8 will have the ability to use VST plugins on the master output signal, so that a multi band compressor could be used live.
geposted Fri 27 Jul 12 @ 6:33 am
We need Vdj 8 to come out to take thing further I pretty board of my pa
geposted Fri 27 Jul 12 @ 7:25 am
Find a GOOD source and get your tracks from there then set VDJ to auto/remember and then use your meters on your mixer. If your controller doesn't have them I'd say you need to upgrade your equipment pronto........
geposted Fri 27 Jul 12 @ 9:26 am
By "good source" Beat, are you talking 320kbs and up?....Is that the "standard?"......Do the VU Meters represent the volume going out or the gain levels of the deck?.....thanks.....
geposted Fri 27 Jul 12 @ 2:33 pm
