Forum: VirtualDJ Skins
Topic: skin, script problem
aubs123PRO InfinityMember since 2006
HI, I've added a filter on/off light button to my skin, like DJdads dark default one
this is the script I've used
<slider action="deck 1 filter" orientation="round">
<pos x="48" y="276"/>
<size width="21" height="19"/>
<up x="48" y="276"/>
<over x="48" y="276"/>
<down x="48" y="276"/>
<clipmask x="565" y="2323"/>
<fader anglemin="-160" anglemax="+160">
<mask x="566" y="2284" />
<pos x="563" y="2345" />
</fader>
</slider>
<button action="deck 1 filter 50%">
<pos x="76" y="278"/>
<size width="26" height="18"/>
<down x="16" y="2425"/>
<selected x="+0" y="+0"/>
<up x="16" y="2425"/>
</button>
with the above it ether resets its self when a new song is loaded or if clicked on with the mouse
i use a Denon mc3000 which has a designated filter knob, what i would like is when i turn the filter knob back to the center position it turns the light back off
thanks aubs
geposted Sun 05 Aug 12 @ 6:21 am
you could try
<button action="deck 1 filter 50% & deck 1 filter 50% ? off : on">
This one should grab your attention a little better though
<button action="deck 1 filter 50% & deck 1 filter 50% ? off : blink 300ms ">
geposted Sun 05 Aug 12 @ 6:39 am
djjbPRO InfinityMember since 2004
Hi,
I found the same problem and I think it's a controller issue. Your button is off only when the slider is exactly at 50%. Not 49% or 51% so it's very difficult to set the controller slider at 50%. Try the button in a skin with the slider in a skin, then you know if it's working.
I think whe need a marge, but I don't know how.
geposted Sun 05 Aug 12 @ 2:15 pm
You could map the led as following:
deck 1 get filter & param_smaller 45% ? on : param_greater 55% ? on : off
Haven't tried it since I don't use the built in filter but it should work...
geposted Sun 05 Aug 12 @ 2:35 pm
thanks for all the help but still cant get it to work
synthet1c
your first suggestion lights it when moved but doesn't turn off
second doesn't do ether
phantom
couldn't get to turn on or off with that ether
djjb
i think you might be right maybe be its just not possible
if i turn the knob on the skin with the mouse and then press the button, it will turn off and set the knob back to the center position so i'm sure that works fine
I've looked at the mapping in the mc3000 file and the filter is just mapped to
"FILTER" action="filter" />
so i cant really give you guys anymore to go on
thanks again for trying to help though aubs
geposted Sun 05 Aug 12 @ 3:18 pm
Map the FILTER knob of your controller as
param_smaller 45% ? set 'filter0' 0 & filter : param_greater 55% ? set 'filter0' 0 & filter : set 'filter0' 1 & filter
and in the skin, for the button have this as action..
<button action="deck 1 var 'filter0' ? on & deck 1 filter 50% : off & deck 1 filter 50%">
geposted Sun 05 Aug 12 @ 4:03 pm
superb that works great, thank you just what i wanted
again to all of you respect, that script mapping just goes straight over my head lol !!
geposted Mon 06 Aug 12 @ 9:29 am
