I tested VDJ 7.3
I have problem with Pioneer XDJ-AERO.
If I have vinyl mode and I use jog as (jog pitch+/-) I have bad sound. Sound like water.
If I have CD mode and I use jog I have ok sound.
Can you help me?
Thank you.
Can you help me?
Thank you.
geposted Sun 30 Dec 12 @ 3:43 pm
Please do not post the same message or question more than once.
You have already asked this question in the following topic in the hardware technical support forum, which is a more appropriate location: http://www.virtualdj.com/forums/104382/x
geposted Mon 31 Dec 12 @ 4:08 am
i have a problem with xdj-aero in vitrual dj it doesnt work?
geposted Fri 10 May 13 @ 3:27 pm
i have just bought a pioneer xdj aero controller and i want to use virtual dj with it but i also want the effects and use of the jog wheel as you get when using the recordbox software, is there anyway i can do this? or can i get a plugin for this? any suggestions are welcome thanks
geposted Sat 05 Oct 13 @ 8:47 am
