Forum: Old versions
Topic: Won't play music from iTunes
So I just got a new laptop and I store all of the music that I use to DJ on a flash drive. I have Virtual DJ LE for the Hercules dj console RMX and all my music is loading fine except for music that I had bought on iTunes. I'm not sure why it's doing this because all of the music that I bought on iTunes would work in VDJ on the computer that I was using, but it just doesn't work on this computer. I even transferred my iTunes account to this computer and tried loading the music directly from iTunes but it still didn't work. I really have no clue what the problem is because the previous computer that I've been using is an old computer with Windows XP and my new laptop has Windows 7. Basically what happens is when I load the song on to the deck, it says .m4aERROR and it doesn't show the BPM or waveform, etc. (Although it does show the BPM for the song in the library) I'm not sure if this has to do with the DRM thing because all of the songs worked fine on my other computer. If anyone knows how to fix this, please help.
geposted Mon 20 Aug 12 @ 4:09 pm
the music that does not work are DRM.
geposted Mon 20 Aug 12 @ 5:20 pm
Sorry, VirtualDJ Console Edition v5 for the RMX is an older version of the software and doesn't support the newer MP4 codecs used by iTunes.
To be able to play these, you will need to upgrade to the latest full Pro v7.0.5b: http://www.virtualdj.com/buy/index.html - Your RMX entitles you to a considerable discount of 50% off the cost of purchasing the full VirtualDJ Pro.
DRM protected (.m4p) files cannot be played in any version of VirtualDJ - Please see http://www.virtualdj.com/wiki/iTunes%20DRM.html
geposted Mon 20 Aug 12 @ 7:15 pm
But they were working perfectly on the same software on my other computer
geposted Mon 20 Aug 12 @ 7:42 pm
If you downloaded them again from iTunes on your new laptop, then they now may be encoded with the new MP4 codec, whereas on your old computer they were not.
Another possibility is that the files are simply not in the correct location (You have moved and/or renamed them outside of VirtualDJ, or have copied across your database and music from your old computer, but not put it in exactly the same path.)
Please see:
http://www.virtualdj.com/wiki/Error%20loading%20song.html
http://www.virtualdj.com/wiki/How%20do%20I%20transfer%20the%20software%20from%20my%20old%20computer%20to%20my%20new%20computer.html
geposted Tue 21 Aug 12 @ 6:52 am
I got it to work, all I had to do was download Quicktime
geposted Sun 16 Sep 12 @ 4:07 pm
Pourquoi j'arrive plus à jouer toute music enregistrée à partir de VIRTUAL DJ PRO 7 sur itunes? elle est enregistrée maintenant sur VLC besoin d'aide svp..merci
geposted Sun 09 Mar 14 @ 3:34 am
Usually, when record any music from VIRTUAL DJ, it goes to my desktop and then open by itunes appilcation...now I can't open any more with itunes...need help please thanks
geposted Sun 09 Mar 14 @ 3:37 am
