Hi Guys,
Does anyone have any idea why a plugin would appear blank in vDJ? Please see screenshot attached.
- vDJ 7.0.5b
- vDJ was completely removed (inlcuding deleting registry branch) and reinstalled but the effect still shows blank in vDJ.
- From screenshot, you can see 2 filter effects \"Filters_HiLow and \"TexZK\". Both of these together with the another filter named ???380 behave in the same way.
- All other plugins work normally. The problem is only with Filter plugins.
Any advise welcome.
- vDJ 7.0.5b
Any advise welcome.
geposted Tue 21 Aug 12 @ 4:57 pm
you probably need to update your C runtime libraries and direct x, not sure if and vdj effects use dot net but you should upgrade that too. Tex has links on his homepage.
geposted Tue 21 Aug 12 @ 6:46 pm
You Should have all these installed,
Microsoft Visual C++ 2010 Redistributable Package (x86) http://www.microsoft.com/en-us/download/details.aspx?id=5555
Microsoft Visual C++ 2005 SP1 Redistributable Package (x86) http://www.microsoft.com/en-us/download/details.aspx?id=5638
Microsoft Visual C++ 2008 SP1 Redistributable Package (x86) http://www.microsoft.com/en-us/download/details.aspx?id=5582
The Microsoft DirectX® End-User Runtime provides updates to 9.0c http://www.microsoft.com/en-us/download/details-a.aspx?id=35
Good Luck,
Joey...
Good Luck,
Joey...
geposted Tue 21 Aug 12 @ 7:04 pm
Thanks for the replies!
I'll check it out.
I'll check it out.
geposted Tue 21 Aug 12 @ 9:50 pm
Esque je peut téléchargé des Effect la
geposted Wed 29 Aug 12 @ 7:56 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
Effects and other add-ons are only available to registered licensed users who have purchased the software: http://www.virtualdj.com/products/comparison.html
geposted Wed 29 Aug 12 @ 8:11 am
Just to help someone else; the reply by Joey is the answer to the problem. THANKS JOEY!
geposted Wed 05 Sep 12 @ 8:17 am
