Topic: How To: Numark Mixdeck Quad 4
Hi,
I just purchased the Numark Mixdeck Quad 4. I would like to know if there are any tutorials that will show how to use all the functions. The manual that came with the controller is very vague. I'd like to know in depth how to's such as; How to cue and/or fade from deck to deck using CD's, etc. Also more info on connections. Any help would be appreciated.Thanks, Ray
geposted Mon 27 Aug 12 @ 7:25 pm
Hi JoeyKJ,
Thanks for your reply. All I could see was answers to mapping. I'm looking for step by step instructions on how to cue from one CD deck to the other as well as other functions of the Mixdeck Quad itself. Thanks again for the help, Ray
These guys on that thread are one's & two's you need to talk too...after all they have the stuff you need to fluff.....and spin fluffily there after...
Hi,
Thanks for your input! I'm sure there will be more in depth information as more of these controllers get out there. Thanks again, your help is very much appreciated. Ray
tambem quero o mapper
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
NOTE: The MixDeck Quad is natively supported in the latest full VirtualDJ v7.4 Pro, so no mapper is required. You will need to purchase the full VirtualDJ Professional to be able to use MIDI controllers. If you like VirtualDJ, then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html
If you have already purchased VirtualDJ Pro, then please register your Pro serial number to your account http://www.virtualdj.com/users/edit.html and then download the latest v7.4 version from the Download Center: http://www.virtualdj.com/download/updates.html
