Hi, im using DDJ-ERGO with Virtual DJ LE and i have problem with this software. Before holidays i bought this controller and i was using Virtual DJ PRO (20-days trial version) so in VDJ PRO i could change standard button in options - no problem. But now when i have Virtual DJ LE i cant change standard button's but i need it to use my microphone. Today i found file: Pioneer DDJ-ERGO mapping in C:\Documents and Settings\xxx\My Documents\VirtualDJ\Mappers and i try to edit this in notepad but i dont know what is what :P
Can you write me here command to change buttons like on this photo or say how to use microphone by ddj-ergo?
Thanks!
http://img577.imageshack.us/img577/3074/beznazwy2uf.jpg
Commands from file:
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="DDJERGO" author="Pioneer Corp and Atomix Productions" description="Pioneer DDJ-ERGO VirtualDJ" version="705" date="26/08/2012">
<map value="PLAY" action="play_pause" />
<map value="CUE" action="cue_play" />
<map value="JUMP_START" action="stop" />
<map value="VINYL_MODE" action="vinyl_mode" />
<map value="KEYLOCK" action="key_lock" />
<map value="LOOP_IN" action="loop_in" />
<map value="LOOP_OUT" action="loop ? reloop_exit : loop_in ? loop_out : reloop_exit" />
<map value="ENC_AUTO_LOOP" action="loop_double" />
<map value="BTN_AUTO_LOOP" action="loop" />
<map value="ENC_MOVE_GRID" action="param_smaller 0 ? adjust_cbg -1% : adjust_cbg +1%" />
<map value="LOOP_MOVE-" action="loop_move -1" />
<map value="LOOP_MOVE+" action="loop_move +1" />
<map value="RELOOP" action="reloop" />
<map value="VID_PARAM" action="video_transition_slider 1" />
<map value="VID_TRANS_ACTIVE" action="show_pluginpage "Video Transitions" & video_transition" />
<map value="VID_FX_ACTIVE" action="show_pluginpage "Video Effects" & video_fx" />
<map value="VID_TRANS_SELECT" action="video_transition_select +1" />
<map value="VID_FX_SELECT" action="video_fx_select +1" />
<map value="RANGE_6" action="pitch_range 6%" />
<map value="RANGE_10" action="pitch_range 10%" />
<map value="RANGE_16" action="pitch_range 16%" />
<map value="RANGE_100" action="pitch_range 100%" />
<map value="PITCH" action="pitch_slider" />
<map value="HOT_CUE_1" action="hot_cue 1" />
<map value="HOT_CUE_2" action="hot_cue 2" />
<map value="HOT_CUE_3" action="hot_cue 3" />
<map value="HOT_CUE_4" action="hot_cue 4" />
<map value="DEL_HOT_CUE_1" action="delete_cue 1" />
<map value="DEL_HOT_CUE_2" action="delete_cue 2" />
<map value="DEL_HOT_CUE_3" action="delete_cue 3" />
<map value="DEL_HOT_CUE_4" action="delete_cue 4" />
<map value="SYNC" action="sync" />
<map value="MASTER DECK" action="masterdeck" />
<map value="FX_ON" action="show_pluginpage "Sound Effects" & effect active" />
<map value="FX_1" action="effect button 1" />
<map value="FX_2" action="effect button 2" />
<map value="FX_3" action="effect button 3" />
<map value="FX_4" action="effect button 4" />
<map value="FX_5" action="effect button 5" />
<map value="FX_6" action="effect button 6" />
<map value="FX_D1" action="show_pluginpage "Sound Effects" & effect "beatgrid" active" />
<map value="FX_D2" action="show_pluginpage "Sound Effects" & effect "flanger" active" />
<map value="FX_SELECT" action="skin_panel "deck1c" ? effect select : skin_panel "deck1c" on & effect select" />
<map value="FX_PARAM_1" action="effect default slider 1" />
<map value="FX_PARAM_2" action="effect default slider 2" />
<map value="FX_PARAM_3" action="effect default slider 3" />
<map value="FX_PARAM_4" action="effect default slider 4" />
<map value="FX_PARAM_5" action="effect default slider 5" />
<map value="FX_PARAM_6" action="effect default slider 6" />
<map value="FILTER" action="filter" />
<map value="SAMPLER_1" action="sampler 1 play_stop & page "sampler"" />
<map value="SAMPLER_2" action="sampler 2 play_stop & page "sampler"" />
<map value="SAMPLER_3" action="sampler 3 play_stop & page "sampler"" />
<map value="SAMPLER_4" action="sampler 4 play_stop & page "sampler"" />
<map value="SAMPLER_5" action="sampler 5 play_stop & page "sampler"" />
<map value="SAMPLER_6" action="sampler 6 play_stop & page "sampler"" />
<map value="SAMPLER_7" action="sampler 7 play_stop & page "sampler"" />
<map value="SAMPLER_8" action="sampler 8 play_stop & page "sampler"" />
<map value="STUTTER_SAMPLER_1" action="page "sampler" & sampler 1 play_stutter" />
<map value="STUTTER_SAMPLER_2" action="page "sampler" & sampler 2 play_stutter" />
<map value="STUTTER_SAMPLER_3" action="page "sampler" & sampler 3 play_stutter" />
<map value="STUTTER_SAMPLER_4" action="page "sampler" & sampler 4 play_stutter" />
<map value="STUTTER_SAMPLER_5" action="page "sampler" & sampler 5 play_stutter" />
<map value="STUTTER_SAMPLER_6" action="page "sampler" & sampler 6 play_stutter" />
<map value="STUTTER_SAMPLER_7" action="page "sampler" & sampler 7 play_stutter" />
<map value="STUTTER_SAMPLER_8" action="page "sampler" & sampler 8 play_stutter" />
<map value="SAMPLER_PAGE" action="page "sampler"" />
<map value="SAMPLER_ON" action="page "sampler" ? sampler default play_stop : sampler default play_stop & page "sampler"" />
<map value="SAMPLER_VOL" action="sampler volume" />
<map value="SAMPLER_SELECT" action="sampler select" />
<map value="JOG" action="touchwheel_touch" />
<map value="JOG_SEARCH_TOUCH" action="wheel_mode "search" while_pressed" />
<map value="JOG" action="touchwheel" />
<map value="JOG_SEARCH" action="jogwheel" />
<map value="MAIN_VOLUME" action="master_volume" />
<map value="CUE_MIX" action="headphone_mix" />
<map value="HP_VOLUME" action="headphone_volume" />
<map value="GAIN" action="gain_slider" />
<map value="EQ_HIGH" action="eq_high" />
<map value="EQ_MID" action="eq_mid" />
<map value="EQ_LOW" action="eq_low" />
<map value="VOLUME" action="volume_slider" />
<map value="MIC VOL" action="mic_volume" />
<map value="CROSSFADER" action="crossfader_slider" />
<map value="PFL" action="pfl" />
<map value="CHNG_PANEL" action="skin_panel "mixer" ? skin_panel "video" : skin_panel "video" ? skin_panel "scratch" : skin_panel "mixer"" />
<map value="RECORD" action="record" />
<map value="LOAD" action="load" />
<map value="BROWSE" action="browser_window "folders" ? browser_window "songs" & browser_scroll : browser_scroll" />
<map value="BROWSE_FOLDERS" action="browser_window "folders" ? browser_scroll : browser_window "folders" & browser_scroll" />
<map value="BROWSE_PUSH" action="page "browser" ? browser_zoom : nothing" />
<map value="BROWSE_FOLDERS_PUSH" action="browser_folder" />
<map value="LED_LOOP" action="loop" />
<map value="LED_PLAY" action="loaded ? pause ? blink : play" />
<map value="LED_CUE" action="loaded ? cue ? on : play ? off : blink" />
<map value="LED_LOOP_IN" action="loop_in ? blink : loop ? blink : on" />
<map value="LED_LOOP_OUT" action="loop_out ? blink : loop ? blink : on" />
<map value="LED_VID_TRANS_ACTIVE" action="video_transition" />
<map value="LED_VID_FX_ACTIVE" action="video_fx" />
<map value="LED_FX_D1" action="effect "beatgrid" active" />
<map value="LED_FX_D2" action="effect "flanger" active" />
<map value="LED_FX_ON" action="effect active" />
<map value="LED_SYNC" action="sync" />
<map value="LED_PREVIEW" action="prelisten" />
<map value="DNC_VDJ_CONNECT" action="get deck" />
<map value="DNC_VDJ_2DECKS" action="get decks 2 ? on : off" />
<map value="DNC_LOAD" action="load_pulse" />
<map value="DNC_LOOP" action="get active_loop" />
<map value="DNC_RANGE_6" action="pitch_range 6%" />
<map value="DNC_RANGE_8" action="pitch_range 8%" />
<map value="DNC_RANGE_10" action="pitch_range 10%" />
<map value="DNC_RANGE_12" action="pitch_range 12%" />
<map value="DNC_RANGE_16" action="pitch_range 16%" />
<map value="DNC_RANGE_20" action="pitch_range 20%" />
<map value="DNC_RANGE_25" action="pitch_range 25%" />
<map value="DNC_RANGE_33" action="pitch_range 33%" />
<map value="DNC_RANGE_50" action="pitch_range 50%" />
<map value="DNC_RANGE_100" action="pitch_range 100%" />
<map value="DNC_BEATPHASE" action="get beatdiff" />
<map value="DNC_VU_METER" action="get vu_meter" />
<map value="DNC_BEATGRID" action="get beatpos & param_mod 1.0 & param_smaller 0.25 ? on : off" />
<map value="DNC_LEFTCROSS" action="leftcross" />
<map value="DNC_RIGHTCROSS" action="rightcross" />
<map value="MIC_VOL" action="mic_volume" />
<map value="DNC_PITCH" action="pitch" />
<map value="DNC_VOLUME" action="volume" />
</mapper>
Thanks!
Commands from file:
</mapper>
geposted Fri 31 Aug 12 @ 4:17 pm
The mapping is the modified version that you created while using the Pro trial.
It won't work with VirtualDJ LE because it's free limited software and doesn't support custom mapping - See comparison.
To be able to custom map your controller and much, much more, you will need to upgrade to the full VirtualDJ Professional. There is a discount to upgrade from VirtualDJ LE: http://www.virtualdj.com/buy/index.html
geposted Sat 01 Sep 12 @ 1:13 pm
Hi,
I bought a Pioneer DDJ Ergo V controller witch the Virtual DJ LE software, but I can't record anything :( The manual says: Set in such a way that the file path to the location where the recording is stored does not contain 2-byte codes (used in Japanese, etc.). How and where can I do that. Help please.
Thank you.
Thank you.
geposted Tue 10 Dec 13 @ 1:26 pm
Not sure if the LE version, allows you to change the path for your recordings.
If that is the case, then maybe a special character in your computer UserName is causing issues.
Try to create an additional user in your Operating system (with admin rights), dont use any special characters for eh Username (just plain latin ones) and install VirtualDJ under this new user.
If the LE version offers a CONFIg button right above the START button in the RECORD page of BROWSER, then try to choose a folder that has no special character in the path .. e.g. C:\Recordings . Create such a folder, if not available, and make sure you have Read/Write permissions too.
see if that helps.
see if that helps.
geposted Tue 10 Dec 13 @ 2:44 pm
Have you tried recording to a new folder?
geposted Tue 10 Dec 13 @ 2:46 pm
