As the title says, what are controllers that can be used with timecodes and it doesn't matter what software comes with it....
Thanks for the info
Huey
P.S. please don't say any controller as long as you have a soundcard, I only wanna know about the ones with a soundcard built in.
Thanks for the info
Huey
geposted Tue 04 Sep 12 @ 3:26 pm
Controllers
Mixers
That's all I can think of off the top of my head, although maybe the VCI-400, VCI-380 & RMX2 will be capable aswell, but not certain. If your going to use timecodes with a controller I think that the Xone DX would be the best as the controls feel nice and your not using the crappy jogs anyway.
- reloop digital jockey 3
- stanton djc.4/voxoa c50, c60
- Numark N4
- Numark NS6
- American Audio VMS4
- Hercules RMX
- Hercules 4MX
- Kontrol S4
- Xone DX
Mixers
- Xone 4d
- Xone 3d
- Pioneer DJM-850
- Pioneer DJM-900
- Pioneer DJM-T1
- Denon X1600
- Denon X1700
- Rane TTM57-SL
- Rane 62
- Rane 68
- American Audio DV2
- Reloop IQ2
geposted Tue 04 Sep 12 @ 3:46 pm
Add Hercules MK2 to list of controllers
and also add Korg Zero4 and Zero8 (Both mixers are also Traktor Scratch certified) and Denon DN-X600 (Also traktor compatible on PC since it uses the same PC driver as DN-X1600 which is Traktor Certified)
geposted Tue 04 Sep 12 @ 5:15 pm
what isnt the djm 700 on that list
geposted Tue 04 Sep 12 @ 5:25 pm
Reloop Terminal mix 4....but only one TT , The TM4 only has 1 Aux in.
geposted Tue 04 Sep 12 @ 6:18 pm
cause the DJM-700 doesn't have a soundcard ;-)
you can probably add the VOXOA M70 to the list as well, as it should be released soonish and a great mockup of the DJM-T1 but with more controls.
geposted Tue 04 Sep 12 @ 11:49 pm
Denon DNX600 mixer also has built in soundcard. :)
geposted Wed 05 Sep 12 @ 7:52 am
AA VMS4 controller also works with timecodes (I missed it on the list, saw it after I posted). Can be used as an external/standalone mixer or a hybrid of 2-4physical decks and a controller.
geposted Wed 05 Sep 12 @ 9:19 am
After seeing this video I'm gonna go with this one,
Might even switch over for audio gigs and stick to VDJ for video......... hopefully 8 is inline with Trakor's sampler, also in the latest Maschine video i could swear theres some sort of video going on in the background. If they get video its a wrap!!
geposted Wed 05 Sep 12 @ 12:33 pm
