Okay I have been messing around with the controller trying to map certain led-buttons perform a vu meter.
My thought was to take Loop Select, Effect, Delete, Hot cue 1, 2, and 3 and have the LEDs flash like a VU meter.
I tried the following script to accomplish this and it just does not work right
loaded ? play ? get vu_meter 0%peak : off
I replaced the "0" with 20, 40, 60, 80, 100 for the remaining 5 buttons starting at loop select going up and across...
The interesting item is that it seems to work but not how you would think in the intended pattern. Any ideas?
Also I am hearing rumors that the LEDs color can be changed from yellow to red or green, is this true? And if so what is the code?
Thank you in advance.
geposted Wed 05 Sep 12 @ 10:41 am
