I have an android app called Dj Control. It uses a DSMI Wfi Connection to connect to Dj software. I was wondering if anyone know how to set this up...or if it even works
Any Help Is Very Appreciated!
Thanks,
Cory
Thanks,
Cory
geposted Sat 08 Sep 12 @ 3:07 pm
Virtual DJ has iRemote that will allows you to control VDJ via iPad/iPhone but you need the VDJ pro version 7.
Check out this page.
http://www.virtualdj.com/forums/143776/PC_Version_Technical_Support/iRemote_and_PC.html?search=VDJ%20iremote%20&page=1
geposted Sun 09 Sep 12 @ 3:56 pm
iRemote only works with Apple devices though. Android is not currently supported.
If this DJ Control app is able to connect to your computer running VirtualDJ and act as a standard MIDI device then it should be possible to map it in VirtualDJ to control functions of the software (You would need to purchase the full VirtualDJ Pro to be able to do this.) Otherwise it is not possible to use it with VirtualDJ.
For remote control on Android, currently the best option is to use remote desktop software.
Android may be supported in a future version update of iRemote.
geposted Mon 10 Sep 12 @ 5:16 am
