Is it possible to switch between one colored waveform / scratchwave / main wave to colored waveform?
I like this new feature but want to give the user the possibility to switch.
Greets
Music234
Greets
Music234
geposted Fri 12 Oct 12 @ 1:04 am
Samething I was working on and its kickin my butt, lol!! I figured I could just add a "scratchwave" panel but it didnt work sooooooo I'm going to bed and when I wake up we'll have an answer, lol!
geposted Fri 12 Oct 12 @ 1:10 am
^^ nothing is easier than that... go to config and on the bottom-left oft the settings windows you find?! COLORED WAVEFORMS on-off
geposted Wed 17 Oct 12 @ 5:39 am
we are looking for the skript-command
geposted Wed 17 Oct 12 @ 5:47 am
Well I figured a skin master would of chimed in by now.......... so what I did was cut my main waveform in half and then I just added horizontal scratch waves above that. Then added a button to shut off the main wave. The scratch waves aren't stacked but it does serve it's purpose, lol! I'll post a picture when I get home tonight.
Did you even bother to try and read what were asking for here?? Seriously..........
geposted Wed 17 Oct 12 @ 9:02 am
http://www.virtualdj.com/forums/169880/VirtualDJ_Skins/horizontal_color_waveform_question.html
but forget the possibility to fast change the wave zoom like now and also the square under the wave, it will be possibile only in VDJ 8 I think.
djdad wrote :
Only <scratchwave> can be multicolored. So you can create a horizontal scratchwave by changing the orientation to horizontal...
e.g.
<scratchwave deck="1" orientation="horizontal" length="3000">
e.g.
geposted Wed 17 Oct 12 @ 9:19 am
