Hi All,
I have an IMX02 USB external mixer that I have used with my PC and Virtual DJ for years with no problems.
I recently changed to a new Imac, I downloaded the latest version of Virtual DJ.
I have set up the external mixer on the Imac as per the instructions
However, when playing virtual dj, the sound only appears to be coming out of 1 of the soundcards on the mixer. Both decks play out of one side and I crossfade to silence.
The mac can see both soundcards in the settings.
Is this a common thing with the mac? is there a simple fix?
Cheers
Cheers
geposted Mon 15 Oct 12 @ 3:42 am
You probably just need to configure it in MacOS for 4 channel audio. Please see our FAQ pages:
http://www.virtualdj.com/wiki/Configure%204%20channel%20audio%20on%20Mac.html
geposted Mon 15 Oct 12 @ 5:58 am
Nope, doesn't give me that option.
The mixer shows up as on my audio and midi settings as 2no. USB Audio CODEC, with only 2 channels each.
which makes sense as the mixer has 2no. USB inputs.
I assume this means the mixer has 2no. sound cards with 2 channels on each, but it is only playing out of 1 channel
I've tried everything I can think of.
geposted Mon 15 Oct 12 @ 9:14 am
If it shows up as two separate USB sound cards, then you would need to choose the following sound options:
Inputs: None
Outputs: External Mixer
Sound cards: 2 cards
1st card: Choose first card of the IMX02
2nd card: Chose second card of the IMX02
Click APPLY.
You may need to use the source selection switch (If it has one) to set each channel to the USB input.
Inputs: None
Click APPLY.
geposted Mon 15 Oct 12 @ 11:57 am
