Upcoming update: DN-MC6000 Enhanced (3-1L-R2-4) v1.2
Made some small maintenance updates for the Skin Set to keep it current with new features being tossed around.
http://www.virtualdj.com/addons/12770/DN-MC6000_Enhanced_(3-1L-R2-4).html
Description:
4-Deck Skin Set w/(3-1L-R2-4) Mixer Channel Layout
Here is the Virtual DJ Skin set to setup the DN-MC6000 and other 4-Deck controllers in the (3-1L | R2-4) channel configuration as opposed to the default (1-2L | R3-4) configuation. You will need the matching Controller MAPPER for this Skin set to work properly.
Included Resolutions:
- 1280x768 [16:9] (native)
- 1280x800 [16:10] (native)
- 1280x1024 [5:4] (native)
- 1440x900 [16:10] (upscaled)
- 1600x900 [16:9] (native)
- 1680x1050 [16:10] (upscaled)
- 1920x1080 [16:9] (native)
Features:
- (3-1L-R2-4) Mixer Channel Layout
- Indicators for Smart Play, Slip Mode, Protected Cue, Master Channel Active Limiter
- Synchronized transport control lighting with the use of the controller MAPPER file
- Font Size selectors, 5 sizes available.
Additional notes:
- Matched DN-MC6000 controller Mapper file available in the CONTROLLERS section:
http://www.virtualdj.com/addons/12744/DN-MC6000_Ch_3_1_L-R_2_4_Mapper.html)
- Bug reports or feedback would be greatly appreciated :)
*** Revision history ***
Version 1.2 changes:
- Added 1600x900 and 1920x1080 resolutions
- Fixed several minor cosmetic issues including:
- Fixed Waveforms (patterns, sizing, alignment, CUE marks deformation)
- Fixed Buttons (some buttons not being displayed correctly, missing or out of place)
- Fixed Animation in general (minor artifacts would show up here and there)
- Fixed some channel order handling issues in which some advanced features would still handle the channels as 1-2-3-4
- Added SLIP mode indicator
- Added PROTECTED CUE mode indicator
- Added LIMITER ON indicator. Credit to DJDAD :)
- Added Font Size selector function
- Synchronized transport control lighting with the controller MAPPER file.
Version 1.1 changes:
- This SKIN SET and the XML Controller Mapper file (available separately) now both match the Channel order of (3-1L | R2-4)
Description:
Features:
Additional notes:
geposted Tue 04 Dec 12 @ 1:13 pm
argh, looks like the webmasters are getting stingy on space, can't even upload a 10MB file...
Unfortunately I have to remove 2 resolutions for the time being, which 2 are the least used ones?
- 1280x768 [16:9]
- 1280x800 [16:10]
- 1280x1024 [5:4]
- 1440x900 [16:10]
- 1600x900 [16:9]
- 1680x1050 [16:10]
- 1920x1080 [16:9]
- 1280x768 [16:9]
- 1280x800 [16:10]
- 1280x1024 [5:4]
- 1440x900 [16:10]
- 1600x900 [16:9]
- 1680x1050 [16:10]
- 1920x1080 [16:9]
geposted Tue 04 Dec 12 @ 4:09 pm
I'm having trouble uploading the new Skin set, Atomix support is looking into this....
geposted Fri 07 Dec 12 @ 12:24 pm
Ok, the [16:9] skins are up, I'll post the [16:10] skins at a later time, enjoy...
geposted Fri 07 Dec 12 @ 6:06 pm
Supplement resolutions have been submitted for approval...
http://www.virtualdj.com/addons/15474/DN-MC6000_Enhanced_(3-1L-R2-4)__b_.html
geposted Mon 17 Dec 12 @ 1:25 pm
Thanks.
Supplement resolutions now available for download:
Part1: http://www.virtualdj.com/addons/12770/DN-MC6000_Enhanced_(3-1L-R2-4).html
Part2: http://www.virtualdj.com/addons/15474/DN-MC6000_Enhanced_(3-1L-R2-4)__b_.html
Once you have downloaded both files you may combine all extracted files into a single ZIP file for your convenience, just name it:
"DN-MC6000 Enhanced (3-1L-R2-4) v1.2.zip"
Feedback is appreciated :)
geposted Thu 20 Dec 12 @ 3:05 pm
Hi! Thanks for the skin.
I made a change too better suit my need, so it will work like: 1/3L 2/4R
The only thing I didn't figure is how to change the color of the VU-METERS and the PFL switch.
May someone tell me where it is in the xml file?
thanks
Jean-Francois
thanks
Jean-Francois
geposted Fri 04 Jan 13 @ 2:06 pm
Open the XML and search for "VU-METERS", the PFL section should be right below it as well.
geposted Sat 05 Jan 13 @ 1:48 am
