Hi.. the current pitch range for the Pitch slider is 8%, 12%, 34%. Could you put in another setting lower than 8%...I'd like to see 6% (slider would have to move a greater distance to make a pitch change..which translates into tighter adjusting of the mix).
Also the pitch bend buttons i'd like to see an adjustable setting in the config to adjust the sensitivity when i press the + - buttons on the DAC. Right now when u press a button, it jumps by .2%...i'd like to see it .1% for finer adjustment.
Keep up the great work...this program just ROCKS.
Styles Q
Styles Q
geposted Fri 12 Sep 03 @ 11:54 pm
I think it would be a good idea to put in these options
4, 6, 8, 10, 12, 20, 24, 34, 52 and 100%
that will cover just about everyone!
geposted Sat 13 Sep 03 @ 12:07 am
Another nice control would be - direction. -200% to +200%
Its nice for gradual, manual stops, and I like the effect I get when I play a song at 5-15%.
Plus its nice for looking for those subliminal messages.
Btw, did you know that when you play "We in Music - Now that love has gone" backwords you get "buy from Atomix productios please o' please" ;)
geposted Sat 13 Sep 03 @ 9:45 am
