I just got the Numark iDJ3. I found out some things that you guys should know with the iDJ3 and Virtual DJ
For users who had "Unfortunately the installation failed (Error: Timeout - 0x0006)" when installing iDJ3 Driver version 2.9.11 x86/x64. I don't think it works correctly. I'm gonna call Numark for this issue. I think it only works for Mixvibes, not Virtual DJ but I'm not sure.
XP Users, install one of these hotfixes (or both if you want, which I did that), XP SP3 users should have KB888111 integrated:
KB835221 UAA Initial - [link removed]
KB888111 UAA Rev 1.0a for XP SP2 or below - [link removed]
It should recognize iDJ3 as USB Composite Device > USB Audio Device.
Vista and 7 should have the drivers for it.
For better functionality of the iDJ3 without the microphone, use Virtual DJ LE (7.0.3) for iDJ3. Download: http://www.numark.com/virtualdjleupdate
I assume that if you want to install iDJ3 Driver version 2.9.11 x86/x64 successfully, I think you have to update the iDJ3 firmware to v1.03 and use Midi Ox to upload firmware, then hold Cue A, Cue B.
Firmware: [link removed]
Midi Ox 7.0: [link removed]
Midi Ox SE: [link removed]
Midi Ox 6.2.0: [link removed]
geposted Sun 20 Jan 13 @ 3:40 pm
I have removed your 'get paid for sharing' links, as well as links to unofficial sources. The IDJ3 firmware is on Numarks site:
http://www.numark.com/images/product_downloads/idj3update.zip
MIDI OX have their own website:
http://www.midiox.com/
MS hotfixes should be obtained from MS themselves, but anyone running anything older than XP SP3 need their head looking at anyway.
Instructions for updating the IDJ3 firmware are included in the PDF bundled with the firmware too. Also see here:
http://www.virtualdj.com/wiki/iDJ3.html
geposted Sun 20 Jan 13 @ 4:00 pm
