What are my options if I dont have a CD input??
geposted Mon 21 Jan 13 @ 3:08 am
What do you mean by 'CD input'?
If you mean the ability to play audio CD's, then you can do this by simply putting the CD in your computer's CD drive and then browsing to it in VirtualDJ's browser. However, you should should ideally 'rip' all your CD's to digital format (E.g: MP3) so the songs can be loaded and played directly in VirtualDJ.
If you wish to input external CD or vinyl decks through the software mixer in VirtualDJ then you will need a sound card with a suitable number of inputs and either VirtualDJ Basic or the full VirtualDJ Professional (Home FREE and Broadcaster are more limited versions and have limited sound options, hence the lower price.) The sound card will need at least 4 inputs (2 stereo), such as ESI Maya44 USB or Hercules DJ Trim.
If you wish to use timecode to control VirtualDJ using traditional CD or vinyl decks then you will need a suitable ASIO sound card with at least 4 inputs (2 stereo) and the full VirtualDJ Professional. Please see http://www.virtualdj.com/wiki/Timecode%20Requirements.html
geposted Mon 21 Jan 13 @ 4:06 am
I guess you mean that you ordered a boxed version of the software, but your laptop doesn't have a CD-ROM drive, correct?
In that case you should edit your profile ( http://www.virtualdj.com/users/edit.html ) and register your serial number.
Once you do so you can visit your download center ( http://www.virtualdj.com/download/updates.html ) and download the installation file to your PC.
geposted Mon 21 Jan 13 @ 5:11 am
i bought the numark mixtrack edge but i can't find the cd.please how can i get my code back?
geposted Mon 15 Dec 14 @ 1:58 pm
Please contact support: http://www.virtualdj.com/contact/index.html
geposted Tue 16 Dec 14 @ 5:34 am
