Topic: HELP NOOB QUESTION ABOUT 4 DECK SKIN?
I have a Numark Mixdeck Universal with the Pro version of Virual Dj 7. My question is can I set up a 4 skin deck on this 2 channel controller? I have done it to some success but I cant hear deck 3 or 4? I only have one outout which is a small speaker, do I need another speaker? Thanks everyone and I am a noob so I apologize for the lack of basic knowledge.
geposted Thu 31 Jan 13 @ 5:08 pm
Yes you can but youll have to use the advanced config and route the decks yourself.........
You should also register your software so your always up to date.......
Enjoy
Huey
Thanks Huey, problem is this set up was a gift from my older brother. Any thread you recommend to learn what to input in the Advance Config Screen? I have done a search and have not found anything. I have looked at your videos and admire your set up, it is awesome. How can I do the same? Thanks in advance for your help.
Advanced Config,
Deck 1-Mixdeck ASIO-1/2
Deck 2-Mixdeck ASIO-3/4
Deck 3-Mixdeck ASIO-1/2
Deck 4-Mixdeck ASIO-3/4
Youll have to map some buttons on the Mixdeck or keyboard so you can switch decks and remember the mixer IS NOT MIDI SO IT WON'T CONTROL VDJ.
Enjoy
Huey
