Alright...Now that I've realized that I was having a user error moment...I figured it out, well after reading your post again I finally realized I wasn't RIGHTCLICKING!!!!...Thanks again
geposted Wed 06 Mar 13 @ 2:58 pm
djdad wrote :
5 star 4 Deck skin not to much for the eye and the deck are all the same to work with/& the gain move to match the gain on the other decks when need it.( when I right click on the gain )
keep working on that font side/
geposted Fri 08 Mar 13 @ 4:57 pm
Version 1.1 is available
- Added Sllp Mode and Loop Roll buttons
geposted Wed 20 Mar 13 @ 5:56 pm
i love the skin man but the plates that says VIRUTAL DJ that have the black background are not fitting in.. should of keep it regular man other than that i love this skin too bad i cant download it :( this would of perfectly sit to my need :)
geposted Fri 22 Mar 13 @ 8:02 am
the different colors on the jogwheels indicate which deck is LEFT or RIGHT (rightclick selection on the 1,2,3,4 select button near the jgwheels)
Since i decided to give different colors on the jogwheels, the Red background of the VDJ logo did not fit well. Its all a matter of taste after all :)
geposted Wed 03 Apr 13 @ 6:19 am
I am about to create a True 4 Deck version with no Left-Right logic, in a horizontal layout. Useful for those you have 4 real decks in their setup
I will need your precious opinion :) ... A, B or maybe something different ?
Actually the difference between the 2 different deck layouts is the HotCue layout (horizontal vs vertical) Some units have one or the other. I prefer the horizontal layout as this helps much better with the layout that the hotcues have on the songposition, but still lot of units (CDJs mainly) have the Hotcues on vertical layout).
Thoughts ?
Thoughts ?
geposted Wed 03 Apr 13 @ 6:22 am
or maybe C ?
or even D ?
speak now or forever hold your peace ..lol
or even D ?
geposted Wed 03 Apr 13 @ 6:40 am
Thoughts ?
Thoughts ?
It look like some DJM 800 with four cdj 2000 =)
i hote it wiil have full size resolution.
wainting for the final version (y)
geposted Wed 03 Apr 13 @ 2:35 pm
well, if you dont vote, you wont get anything :P
geposted Wed 03 Apr 13 @ 2:50 pm
vote ?
geposted Wed 03 Apr 13 @ 2:51 pm
@DJDad,
very difficult to vote.
ImO D has the finest layout and structure, and with this layout you have more space for the Cue-Infos.
Greets
Greets
geposted Wed 03 Apr 13 @ 6:58 pm
I prefer the C but without need to show
the hot cues time position (my opinion) use this place for
more hot cue or Fx or tempory loops as slip mode.
geposted Wed 03 Apr 13 @ 9:44 pm
Final call...
Filter moved to Mixer.
Key vs Sample small panels
FX with 3 sliders (will display slider names as well)
Smart Play
S (Slip mode) button
Smart Play
geposted Thu 04 Apr 13 @ 9:08 pm
can it be downloaded ? damn i would love to talk to you about this topick i tried to do some skin work but im not that much talented great work dude :) really loving it :)
ok got it found its on the second page for the newcomers :D thanks dude for making it available
for everybody :)
geposted Fri 05 Apr 13 @ 12:16 pm
maki,
Thats a different skin project. The one you found has different layout. The one you see above (with Vertical layout) will be ready in a few days.
geposted Fri 05 Apr 13 @ 1:55 pm
There will be 2 versions. One with 1-2-3-4 and another with 3-1-2-4 deck order
Each deck has 3 different Views
geposted Fri 05 Apr 13 @ 8:37 pm
What resolutions will this skin be at? I'm kinda liking this. Seems more natural for a 4 deck skin. I'm running 1600x900.
One idea...
Any chance we can have a "deck zoom" capability? As with any multideck skin, getting all this info on the screen means reducing the font and image sizes.
Maybe overlay the deck 1/2 panels for a left zoom and 3/4 for a right zoom. Plus the ability to zoom all deck panels...
Just asking ;-)
Just thinking about how I use VDJ, I tend to stand a good 2ft away from the lappy (I have a 6ft deck stand) and tend to glance at the software to load a track or select an effect. Being able to zoom a deck (via mapped keys/buttons) would be an advantage with such a detailed skin.
Cheers,
Roy
One idea...
Just asking ;-)
Cheers,
Roy
geposted Sat 06 Apr 13 @ 2:49 am
djdad wrote :
maki,
yes djdad i know i was talking about the older skin :) im loving it and thanks for making it available for everybody :) ok no more of topick lets get back to the real deal :D of the new skin hehe
geposted Sun 07 Apr 13 @ 6:49 am
djdad wrote :
Hmm, doesnt look bad at all :)
Great skin! I have one question.The sample knob on my Reloop TM4 controller can adjust the sample volume of any sample button pressed on the TM4 when the sample bar on the bottom screen is not present. When the sample bar is present I can only adjust the volume with the TM4 when I click on the number button in the software to the left of the sample playing. Is there something I can change in my mapping to have the volume knob to automatically control the sample volume without having to click on the number button first with my mouse? (see screenshot).
Thanks
geposted Thu 30 May 13 @ 11:08 pm
The TRACK knob (encoder) of the TM4 offers that. You can select the Sample, only if Sample is not playing (with SHIFT+TRACK when the SAMPLER page is displayed)
If you map the TRACK knob as ..
page "sampler" ? var '$shift' ? sampler volume : sampler select : page "effects" ? show_pluginpage "Sound Effects" ? var '$shift' ? deck active effect slider 1 : deck active effect active ? deck active effect slider 1 : deck active effect select : show_pluginpage "Video Effects" ? var '$shift' ? video_fx_slider 1 : video_fx ? video_fx_slider 1 : video_fx_select : show_pluginpage "Video Transitions" ? var '$shift' ? video_transition_slider 1 : video_transition ? video_transition_slider 1 : video_transition_select : nothing : page "record" ? nothing : var '$shift' ? browser_window "folders" ? browser_scroll : browser_window "folders" on & browser_scroll : browser_scroll
then you will be able to select the Sample even if the Sample is playing.
Alternatively, you can map the LOOP MOVE encoder as ...
var 'shift' ? sampler default select : param_greater 0 ? loop_move +100% : loop_move -100%
or
var 'shift' ? param_greater 0 ? sampler default select +1 : sampler default select +1 : param_greater 0 ? loop_move +100% : loop_move -100%
to select the Sample with SHIFt +LOOP MOVE
PS. Please use the Software Forums of you wish assistance with vdj script actions and mappings. Your request is more or less irrelevant to the skin itself.
or
geposted Fri 31 May 13 @ 1:29 am
