Forum: Music discussion
Topic: Beginner in need of any help possible!!!
I just downloaded the free home version of virtual dj. All I really need to do is mix two songs and add a decent transition in the middle, but I have absolutely no idea what I'm doing. Any help is appreciated.
geposted Tue 26 Feb 13 @ 1:47 am
RobRoyPRO InfinitySenior staffMember since 2012
First of all it is important to select 2 suitable tracks for your fist mixing lesson. When you drop a song in each deck, the software will analyse the beats per minute and the key of the song . At the beginning choose songs which have almost the same bpm and key
Try to match the same beat when playing and prelistenig both songs and try find a an appropriate part in the tracks to try your transition.
There are a lot of tuturials about how to use vdj and how to practice ( that is one of the essential things...;-)
http://de.virtualdj.com/wiki/How-to-DJ%20Tips.html
http://www.youtube.com/results?search_query=virtualdj+tutorial&oq=virtualdj+tutorial&gs_l=youtube.3..0j0i10l9.724.6122.0.6669.24.18.4.2.2.0.135.1511.14j4.18.0...0.0...1ac.nDySlpKCcIw
greetz
rob
geposted Tue 26 Feb 13 @ 5:52 am
roBroY gave a good explanation. I had you're same question when got onto VDJ. First thing I did was read the sticky's at the top of this forum. They really helped. Keep practicing and eventually you'll understand the concept of mixing.
Good Luck!
geposted Tue 26 Feb 13 @ 9:23 pm
