Hey guys i have a big favor to ask.Before i start im a major noob. I have numark kmx02 and a dell inspiron 15r laptop and for the life of me i cant figure out how to pre listen to music while im gigging its a nightmare , ideally if there was a video ye could send me the link to , im useless with names of things so please be patient and thanks in advance for any support...
geposted Thu 14 Mar 13 @ 7:40 am
What version of VDJ are you using?
http://www.virtualdj.com/wiki/Pre-listening%20with%20headphones.html
Keith
Keith
geposted Thu 14 Mar 13 @ 7:46 am
Version 7.0 pro
geposted Thu 14 Mar 13 @ 7:52 am
Please update to version 7.3.
geposted Thu 14 Mar 13 @ 10:04 am
Hey is that whats wrong? how do i do the update? cheers
geposted Sat 16 Mar 13 @ 11:38 am
if you bought the software, register your serial in the download center. then you can download the latest version.
http://www.virtualdj.com/users/edit.html
geposted Sat 16 Mar 13 @ 11:52 am
The guy i paid to put it on my laptop gave me no box or anthing , not sure if maby he downloaded it??
geposted Sat 16 Mar 13 @ 11:57 am
If you did not get the serial you payed for nothing. Just hot air.
You should ask for your serial because without registered version there are no updates,
Greets, Heiko
Greets, Heiko
geposted Sat 16 Mar 13 @ 12:01 pm
When you start he software, in the splash screen, is there an e-mail address?
Don't post it here, raise a support ticket so the guys can help you..
Cheers,
Roy
Cheers,
Roy
geposted Sat 16 Mar 13 @ 2:44 pm
Ok seems i paid for fresh air , it says cracked version , guy i paid for it says its same thing tough luck .. where does this leave me? all i wanna do is be able to pre listen to a track ... Any more ideas? cheers again for the help guys
geposted Mon 18 Mar 13 @ 3:49 pm
You should uninstall that version from your PC as it is illegal.
You can download the home free version which will allow pre-listening.
http://www.virtualdj.com/download/free.html
Then configure it here:
http://www.virtualdj.com/wiki/Pre-listen%20using%20headphones%20in%20VirtualDJ%20Home%20FREE%20or%20Broadcaster.html
Comparison of the different versions here:
Keith
Keith
geposted Mon 18 Mar 13 @ 3:54 pm
The solution to your problem is to either use the free version, or to buy Broadcaster, Pro Basic or Pro Full depending on your requirements.
It'll either cost you nothing, €41, €83 or €250.
You could also buy a cheap DJ controller which includes an LE version of VDJ. You can then upgrade from there at a discount.
geposted Mon 18 Mar 13 @ 3:58 pm
will do keith im sickened , where can i buy the proper vitural dj? what version is the best ? and how much should i pay ??
You can buy it from this site.
Have a look of the comparison above. If you don't have a midi controller than Pro Basic allows use of a multichannel sound card.
You may get on just fine with the home free version however.
Keith
Keith
geposted Mon 18 Mar 13 @ 3:59 pm
