Hello!
I'm planing to do an Slip-Brake & Backspin as found on the Pioneer RMX 1000. I think there are hundreds of Echo-Out solutions on the downloadbase so i'll pass this.
So for those people who know this RMX 1000 thy will know that we need a workaround for VirtualDJ and i wnat now to present this 2 workarounds i thougt of.
The RMX 1000 got 3 Steps of the brake (light-medium-hard brake) that deklares how long the brake will ned until it is braked down. So you can begin a verry soft brake within 3 beats and on the last brake you can perform a verry hard brake. After you released the swich you'll have the song runing again on slip-position.
So those 3 Steks of the switch need a workaround in VDJ.
Here are my 2 solutions:
(1st)
The effect gets 3 buttons where you are able to perform 3 different brake speeds.
(2nd)
The effect gets a slider where you are able to define a minimal brake speed and a maximal brake speed. The slider defines the brakespeed that is between max and min value.
So what would be the best solution - what would be the best?
If you have other suggestions you are welcome to post here.
Best regards
C.Hackl
(1st)
(2nd)
Best regards
C.Hackl
geposted Mon 18 Mar 13 @ 10:13 am
