Forum: VirtualDJ Skins
Topic: I need help "rhythmzone"
Hey Skinner,
i build a new skin and i will create a "daylight" version of these.
My problem is i can't create the rythmzone black on a white background. :(
With the old "rhythm" element i can't the wave mirrored or upsidedown.
Is there a way to make the "rhythmzone" black of white?
Best regards DennYo
geposted Wed 10 Jul 13 @ 10:19 am
Nope, you have to use the old rhythm syntax
geposted Wed 10 Jul 13 @ 1:04 pm
thx djdad
but the old symtax rhythm is not for 4 deck and mirrored waves
geposted Wed 10 Jul 13 @ 4:14 pm
Yes. thats true. Bottom line, you cant have white background and 4 decks. This is something that we will try to address to the next version. If you need to make a white/day/outdoor 4 deck skin, have all the other parts white, leave the rhythm area black, and try to use light colors in order to have the larger contrast possible.
geposted Thu 11 Jul 13 @ 6:51 am
