As the title says, I want to print the text into capitals. I am using the %namecueX along with phantoms skin companion plugin, but as my cues have been labeled in lowercase it doesn't suit the theme of what I am doing as all the other text is in capitals. I know I can just use a typeface that only has capitals but that means the font would need to be installed aswell which isn't ideal.
cheers,
Andrew
cheers,
Andrew
geposted Sat 13 Jul 13 @ 7:41 pm
No, there is no way to force capitals. Unless you include a special font.
geposted Sun 14 Jul 13 @ 12:34 am
