Hi all
Been mixing with the LE version for some time, and recently just upgraded to the pro version. I've noticed you can get an iPad app and was wondering if there's a skin to turn it into an effects pad. Ie. You could have 4 sets of buttons, one for each deck, with lets say six individual buttons to control effects on each deck simultaneously. Total buttons needed would be 24 high would easy fit on the iPad screen.
Is this possible and if so how would I go about making it???
Any help would be greatly appreciated :-)
geposted Tue 06 Aug 13 @ 12:45 pm
There is not such skin available, but you can use this one
https://virtualdj.com/addons/16130/Performance_Pad_for_iRemote.html
it has 3 pages with large buttons. Those are assigned to trigger hotcues and samples, but you can edit the xml file and make them trigger effects.
Let me know if you need any help with the coding.
geposted Tue 06 Aug 13 @ 6:34 pm
Thanks yeah I might look at that, although I read there is a delay between starting the effect and it taking effect (excuse the pun haha) because of WiFi latency?
geposted Sat 10 Aug 13 @ 12:33 pm
Try TouchOSC or Lumer......
geposted Sat 10 Aug 13 @ 1:17 pm
If you intend to have the iPad near to the computer, try the adhoc connection. If not mistaken its a bit faster
geposted Sat 10 Aug 13 @ 2:30 pm
use splash top
geposted Thu 05 Sep 13 @ 5:39 am
