Forum: VirtualDJ Skins
Topic: Blinc Sync Button on Beat?
How can I make thats the Sync Button or others blink to the Beat , in the Skin.
On my Controller its the Mapping for the LED get_beat.
Whats on the Skin XML the varable for it?
geposted Thu 22 Aug 13 @ 4:25 pm
Something like below should do it
<button action="deck 1 sync & deck 1 get beatgrid ? on : off" >
</button>
geposted Thu 22 Aug 13 @ 4:47 pm
No does not work :-(
geposted Fri 23 Aug 13 @ 7:41 pm
sorry you don't need the condition just
action="deck 1 sync & deck 1 get beatgrid"
geposted Fri 23 Aug 13 @ 8:19 pm
No, it doesn't work.Try it out on the pioneer T1 skin.
The Synk Button not blink to the Beat.
But why is this blink by other Skins without a command?
Thanks and have a Great Weekend
geposted Sat 24 Aug 13 @ 3:13 am
by default the command 'sync' will blink to the bass drum (not the beat pulse), It must be an issue with the skin, make sure the button has a <selected x="" y=""/> node, as that is the image that will show when the button is lit up. the above worked perfectly on my skin.
EDIT------------------------------
I though correctly... There is no selected node, add it in like this
<button action="deck 3 sync" rightclick="deck 3 sync while_pressed">
<size width="20" height="21"/>
<pos x="539" y="375"/>
<down x="+0" y="+1088"/>
<selected x="+0" y="+1088"/>
<over x="+0" y="+1088"/>
</button>
geposted Sat 24 Aug 13 @ 3:30 am
Ok but here is not blinkin ..
The Button is only blink when i press the sync button..
It may be that it does not work here because the buttons placed in the middle on the mixer are?
But in other skins where the Synkbuttons on the player are placed they Flash to the beat or bass drum...
geposted Sat 24 Aug 13 @ 3:44 am
That by this Skin the command..
Sync
<size width="24" height="25"/>
<pos x="741" y="452"/>
<down x="+0" y="+1306"/>
<over x="+0" y="+1306"/>
</button>
<button action="deck 1 sync" rightclick="deck 1 sync while_pressed">
<pos x="846" y="452"/>
</button>
<button action="deck 2 sync" rightclick="deck 3 sync while_pressed">
<pos x="1009" y="452"/>
</button>
<button action="deck 4 sync" rightclick="deck 4 sync while_pressed">
<pos x="1114" y="452"/>
</button>
geposted Sat 24 Aug 13 @ 3:45 am
You need to add selected to the buttons
<selected x="+0" y="+1306"/>
</button>
</button>
</button>
</button>
geposted Sat 24 Aug 13 @ 3:58 am
Yes, cool...It works...But it is magic :-)
What does the command <selected x="+0" y="+1306"/>?
geposted Sat 24 Aug 13 @ 4:09 am
geposted Sat 24 Aug 13 @ 4:32 am
Ok thank you ;-)
geposted Sat 24 Aug 13 @ 4:59 am
