Download working fine here, tested on multiple devices. Must be your AV causing the problem.
geposted Mon 04 Nov 13 @ 3:29 am
it was just asking to have the plugin emailed to me as my anti virus is blocking it. I levelled it because I used my personal email. there's no conspiracy "this time" ;-)
geposted Mon 04 Nov 13 @ 3:33 am
yeah i suspected that.forgot i downloaded another AV as well...jeeez..let me quite these two down...
geposted Mon 04 Nov 13 @ 4:00 am
OK . THanks
shida 2014
shida 2014
geposted Tue 12 Nov 13 @ 8:19 am
Dang Spammers!..
geposted Wed 13 Nov 13 @ 10:24 pm
Greetings, where in the van VDJ these commands, thanks for the help ...
1) effect select "filter_sbdj" & param_greater 49% ? param_smaller 51% ? effect "filter_sbdj" active off : effect "filter_sbdj" slider 1 & effect "filter_sbdj" active on : effect "filter_sbdj" slider 1 & effect "filter_sbdj" active on
2) effect 9 select "filter_sbdj" & param_greater 49% ? param_smaller 51% ? effect 9 active off : effect "filter_sbdj" slider 1 & effect 9 active on : effect "filter_sbdj" slider 1 & effect 9 active on
3) Change "deck 1 effect active" to "deck 1 effect 1 active"
Change "deck 2 effect active" to "deck 2 effect 1 active"
Change "deck 1 effect select" to "deck 1 effect 1 select"
Change "deck 2 effect select" to "deck 2 effect 1 select"
Change "deck 1 effect slider 1" to "deck 1 effect 1 slider 1"
Change "deck 1 effect slider 2" to "deck 1 effect 1 slider 2"
Change "deck 2 effect slider 1" to "deck 2 effect 1 slider 1"
Change "deck 2 effect slider 2" to "deck 2 effect 1 slider 2"
Exactly as I do, that I do not change the filter SBDJ FX, and that in the skin the button to move the filter?
geposted Tue 10 Dec 13 @ 12:55 pm
Sorry this is for use with a pionner ddj sx and skin ddj sx of dj dad, thanks for any help ...
geposted Tue 10 Dec 13 @ 9:15 pm
Hi,
this is really a very nice plugin..
What i wanted to ask you is, if there is some chance of changing the plugin, in order to put not only the filter, but also key changes...
I mean, you could scroll both buttons.. is that possible?
Best regards.
Best regards.
geposted Thu 24 Apr 14 @ 8:58 am
Key change is native to the software and is of far better quality than I could accomplish in a plugin.
geposted Thu 24 Apr 14 @ 12:10 pm
Plugin updated to include v8 support.
geposted Mon 12 May 14 @ 4:33 am
is this not the stock filter? I have never compared them..
geposted Mon 12 May 14 @ 5:42 am
good work scott....not tried VDJ8 actually,until enough of this things get updated..ha,ha..no rush I mean..;)
geposted Mon 12 May 14 @ 3:45 pm
Hi SBDJ,
What are action to use your filter with Vdj8 and SX?
I tried those pasted by samirdj21 but they active original filter that I would like substitute with your effect...
can you help me please?
thank you in advance...
geposted Sat 28 Jun 14 @ 4:53 am
i would like to use it on my High_EQ for my mixdeck quad can somebody please help me? i copy them for both eq's but it doesnt work, it activates the effect on both sides, how do i make it useable on EACH SIDE?
geposted Mon 09 Feb 15 @ 10:55 pm
