Has anyone got a file for midi mapping the Xone K2? I know it'll be added V8 but I was hoping there would be something avaiable in the mean time.
geposted Mon 21 Oct 13 @ 11:40 am
You need to be a licensed user to do that, if it's available...
geposted Mon 21 Oct 13 @ 6:01 pm
Hi,
Please help me with a mapping to have the 4x4 Buttons at the Controller bottom mapped similar to the 2x4 Performance pads of the DDJ SX!! Ideally the top 2x4 for left deck(s) and the lower 2x4 Buttons for the pads of right deck(s)...
Please i'm about to get crazy with this!
Thanks a Million!
Aphex
Thanks a Million!
Aphex
geposted Sun 05 Jan 14 @ 5:34 am
Sorry i'll do now a double-post, but i saw that i firstly wrote into the spanish Subforum, wich was not my intention...
I'll hope to get some help ;)
Hi Guys,
i'm actually working on a Mapping for the Xone K2 wich will support the three different LED colours.
I already did a mapping with a Midifighter 3D wich was running well.
But the LED colours are different to map instead to the Midifighter 3D
Now i found this Post for the basic informations and i'm fine with that.
http://www.virtualdj.com/homepage/jpboggis/blogs/4461/Multi-colour_LED_mapping.html
I added the different colours to the "A" knob LED in my Device XML file for the K2 and they're working:
<led value="01" note="0x24" channel="14" name="BUTTON_A_RED_LED" />
<led value="01" note="0x48" channel="14" name="BUTTON_A_AMBER_LED" />
<led value="01" note="0x6C" channel="14" name="BUTTON_A_GREEN_LED" />
Now i did some mapping work for the Knob and the three LED colours in VDJ8:
<map value="BUTTON_A_RED" action="deck 1 play_pause" />
<map value="BUTTON_A_RED_LED" action="deck 1 pause ? off : deck 1 songpos_remain 30000ms ? blink 10ms" />
<map value="BUTTON_A_AMBER_LED" action="deck 1 pause ? on : deck 1 songpos_remain 60000ms ? blink 500ms : deck 1 songpos_remain 30000ms ? off : deck 1 loaded" />
<map value="BUTTON_A_GREEN_LED" action="deck 1 pause ? off : deck 1 songpos_remain 60000ms ? off : deck 1 play ? blink 800ms" />
what it should do:
Amber Colour when it's paused or simply loaded
Flashing green (800ms) when the track is playing
Flashing amber (500ms) on the last minute
Flashing red (10ms) when the track has only 30 seconds left.
Basically it works, but it does not work when i pause the track. Sometimes it works but sometimes the LED turns the light off.
So here are my questions:
Is there a mistake in my mapping?
Is this a Bug of VDJ8?
Is there a more easy / simple way to send the midi notes to the K2 to recieve the Colour of the LED?
Hi Guys,
what it should do:
geposted Thu 29 May 14 @ 12:42 pm
hi, that is exactly what i was looking for....but how and where to put the htlm???
thanks you kindly, D
geposted Fri 17 Jul 15 @ 7:32 am
