Hi all,
Can anyone help me with mapping the buttons on the Filter_v2_Texzk effect?
I'm trying to map the first effect button which activates the 'Loop' but I'm finding that:
a mapping of 'effect button 1' activates the second effect button 'Loop /2' and
a mapping of 'effect button 2' activates the third effect button 'Loop x2'
Anyone know if there is a mapping for the first button 'Loop' in this effect?
Many thanks
Many thanks
geposted Fri 01 Nov 13 @ 6:13 am
it must be zero indexed... use
effect button 0
effect button 0
geposted Fri 01 Nov 13 @ 6:32 am
Hi Syntht1c,
Thanks for the suggestion. Hadn't thought of that.
Just tried 'Effect Button 0' but it doesn't seem to work.
There are five buttons on the top: Loop; Loop /2; Loop x2; Quantize; and db/Oct
[Loop/2 and Loop x2 are also linked to the 5th Slider 'LFO Period']
'Effect Button 1,2 or 3' effect respectively - loop/2; Loop x2 and db/oct,
But still can't seem to find any mapping for the 'Loop' or 'Quantize' buttons whether 'Effect Button 0, 9,99 or anything else for that matter!
Many thanks
Many thanks
geposted Fri 01 Nov 13 @ 6:57 am
Hi,
Is there any way of looking inside the coding of the effect to see what might map this button.
I can open and work with the files for mappers and skins (more or less), but am not sure how to have a look at the insides of the effect .dll file. Is this possible?
Many thanks
Aranyaka
Many thanks
Aranyaka
geposted Sat 02 Nov 13 @ 5:13 am
Sorry, that's not possible without access to the original source code and being able to understand C++ programming language.
Some authors may make their source code available, but you need to be Experienced Pro user level or above to be able to download it.
geposted Sat 02 Nov 13 @ 12:05 pm
