Forum: Old versions
Topic: Mixtrack Quad Not Working Without LE Version?
Hello,
I've been using a Numark Mixtrack Quad. It came with the LE version of VDJ, which I installed. I do have the Pro version of VDJ too though, so I downloaded the mapping and everything worked great.
Then yesterday I uninstalled the LE version to make room on my PC since I only used the Pro version. Now I am unable to configure the correct settings for my controller in the Pro version and I do not have the serial number for the LE version I had before. Any help would be greatly appreciated. Thanks.
geposted Thu 28 Nov 13 @ 9:11 am
geposted Thu 28 Nov 13 @ 9:35 am
abluem97 wrote :
Hello,
CAn You tell me the link you downloaded the mapper from?
Thank You
geposted Mon 17 Mar 14 @ 8:00 am
You don't need the mapper because:
A) You have the Mixtrack Quad VDJ LE software which supports your controller.
B) VDJ Pro supports the MixTrack Quad natively.
If you upgrade your LE version to VDJ Pro full then you will be able to use the MTQ with the built in support.
geposted Mon 17 Mar 14 @ 11:00 am
