Hello , I'm new here and would like to know is it possible to DJ with ONE CDJ . IF so , how would I be able to change decks without a break in the song.
(Night Club DJ)
(Night Club DJ)
geposted Mon 09 Dec 13 @ 1:08 am
Yes, it's possible to use a single timecode if you map a key to toggle the timecode control between the decks.
Please see our FAQ pages: http://www.virtualdj.com/wiki/Toggle%20single%20timecode%20between%20the%20decks%20using%20TAB.html
You will need to purchase the full VirtualDJ Professional to be able to use timecode and/or MIDI controllers. If you like VirtualDJ, then please support the software and its future development by purchasing it, especially if you are a working DJ and making money as a result of using it at your gigs (Which is more than likely the case if you are a night club DJ.))
geposted Mon 09 Dec 13 @ 5:45 am
Is that really possible? I would have thought that switching the deck away from the playing track wold stop that track.
geposted Mon 09 Dec 13 @ 5:57 am
Yes, with a single timecode configuration this is possible. It's designed to work that way. If the timecode control is switched from one deck to the other then the deck that's no-longer under control continues playing internally in software only (As it would do if using mouse/keyboard.)
geposted Mon 09 Dec 13 @ 6:17 am
That's interesting. OK thanks Teamer.
geposted Mon 09 Dec 13 @ 6:33 am
Thanks , let me clarify a little just to make sure i have this correct before i spend the money.
I will be purchasing ONE GEMINI CDJ 700 ... do i need to purchase a CDJ TIMECODE disc or anything ?
geposted Mon 09 Dec 13 @ 2:08 pm
The timecode signal is available to download from here, so you just burn it to your own disc.
geposted Mon 09 Dec 13 @ 2:42 pm
You will not need to download or use any Timecode CD.
Gemini CDJ700 is a midi controller, so you will be able to use and control VirtualDJ by just plugging the unit to a USB port.
It is also bundled with VirtualDJ LE version, so you will be able to use it right out of the box, by following the Setup instructions.. http://geminisound.com/wp-content/uploads/2013/02/CDJ-700_VDJ_Quickstart.pdf
With just a single unit, you will be also able to control all the available decks of the software, by just using the EJECT button which cycles though the available decks of the skin.
geposted Mon 09 Dec 13 @ 3:10 pm
You can also upgrade from the LE version to VDJ Pro at a discount once you've registered the software.
geposted Mon 09 Dec 13 @ 3:28 pm
