Hi!
I modified the default skin and added 16 Hot_Cues into it...
Everything works fine...
On a controller, in the Rhythm-Wave and even changing the names of every Cue-Point works great...
The only problem is:
In the song_pos area there are 10 Hot_Cues displayed...
But whats up with the other 6 points?
Is there a code I could add/change to get all the 16 Hot-Cue-Points displayed in the song_pos area?
Thanks!
Thanks!
geposted Mon 16 Dec 13 @ 5:03 pm
you can't it will only ever show the first 10, you can make a request in the wishes forum for it to be added.
geposted Mon 16 Dec 13 @ 5:06 pm
Ok...
Thank you for your quick request!
geposted Mon 16 Dec 13 @ 5:22 pm
