Forum: Old versions
Topic: playlist total time plugin?
CQ1STHome userMember since 2014
Heya, is there a plugin that can show the total time of a playlist? (much like windows media player and musicbee)
geposted Mon 20 Jan 14 @ 1:54 am
If you put all tracks in the auto-mix section you can see the total length of the tracks combined. Don't know if there's any sort of plugin to see it in an other list section.
geposted Mon 20 Jan 14 @ 2:38 am
Hi. I saw it once, but since then it just reads "Total" beside "AUTOMIX". Is there something I can do to make it appear again?
Thanks
geposted Thu 25 Jun 15 @ 4:40 pm
blckjckPRO InfinityMember since 2008
I'm not at my PC right now so I can't check.
Is your side list slid over to far the the right for it to display?
I know this is visible with the default and Fruit skins.
geposted Sat 27 Jun 15 @ 10:58 am
RobRoyPRO InfinitySenior staffMember since 2012
should be there by default
geposted Sat 27 Jun 15 @ 12:00 pm
How do I get to see this total length for a normal playlist?
geposted Sat 01 Oct 16 @ 10:19 am
Load the playlist in the automix window.
geposted Sat 01 Oct 16 @ 10:22 am
I know that, but surely it's simple to show the total length for a playlist in the same way as it shows for an Automix playlist?
Just seems silly to have to keep moving everything in to an Automix playlist
geposted Sat 08 Oct 16 @ 2:51 pm
Then it's a wish, post it in the appropriate place.
geposted Sat 08 Oct 16 @ 4:12 pm
Development of VDJ 7 has stopped. If the feature does get implemented, it'll be in VDJ 8.
geposted Sun 09 Oct 16 @ 9:31 am
