Forum: Old versions
Topic: DN-MC6000MK2: Remapping volume faders
So, I'm new to VDJ, been using Denon controllers (2500 and 4500), but this is the first time I'm suing a controller with a built in mixer. I'd like to have the volume faders line up straight across, 1-2-3-4 … For some reason after downloading the mapper for the controller and loading it up, it seems to line up 3-4-1-2. How do I change this to get it the way I want with a 4-deck skin. Thanks
geposted Thu 27 Feb 14 @ 10:14 am
JPMBenzPRO InfinityMember since 2014
My issue is that the MC6000 MK2 is not appearing in the "Mappers" section of preferences. It only shows keyboard. Did I miss a step?
Thank you,
JP
geposted Sat 08 Mar 14 @ 8:09 pm
My issue was fixed simply by restarting Virtual DJ. :)
geposted Sat 08 Mar 14 @ 10:10 pm
if it happens again you can go into the mapper and press the button next to the dropdown at the top and select "reinit controllers" to reconnect any/all controllers.
geposted Sat 08 Mar 14 @ 10:45 pm
