Forum: Old versions
Topic: So many crashes on Mac... wow
I am NOT complaining one bit but I forgot how many crashes happen on the mac systems. (All known by VDJ)
Coming out of BPM adjust, scanning tracks, reloading tags... seems to crash at every turn.
I am 100% sure that VDJ8 will be much better so I am patiently waiting.
Thanks again for all the hard work in updating the product. No one is more appreciative than I.
Scott
geposted Tue 25 Mar 14 @ 2:53 pm
Crashes on macbook?
geposted Tue 25 Mar 14 @ 8:42 pm
Haui70PRO InfinitySenior staffMember since 2008
Yes, why not?
A lot of my Mac software crashes from time to time :-)
The BPM adjust crash is well known and also VDJ can crash when you try to scan WMV or WMA files.
Not sure about the formats, because i do only use MP3 and MP4 ;-)
But the reload tag issue is new to me.
Can you please tell me what kind of file does cause the problem and maybe you can send us this file for a look?
geposted Wed 26 Mar 14 @ 2:34 am
Very random. I had to remove all the comments on some of my files and when I chose to reload the tags, it crashed.
I had several tracks selected so I am unsure which one.
I was also BPM'ing tracks at the same time.
geposted Wed 26 Mar 14 @ 6:54 pm
geposted Thu 27 Mar 14 @ 2:36 am
I would bet you are correct.
I only use MP3's at 320, therefore, I won't needing the link. I convert an iTunes media to mp3.
Thank you again. I am sure that the rewrite will work out all of the VDJ problems on the Mac.
geposted Thu 27 Mar 14 @ 8:35 am
You're welcome :-)
geposted Thu 27 Mar 14 @ 10:57 am
Add another - Crash on upload new skin to iPad.
geposted Fri 28 Mar 14 @ 12:12 pm
Crash loading clips into the clip bank.
geposted Fri 28 Mar 14 @ 12:21 pm
I know this can be done on the PC side but the ability to put playlists within folders would be very nice to have.
Hopefully we see that in VDJ8.
geposted Fri 28 Mar 14 @ 12:34 pm
What kind of skin?
What kind of format do you use?
Please delete all files from clipbank side and then try to relod teh files again.
geposted Mon 31 Mar 14 @ 6:33 am
Will try.
I was trying to upload updated default skin to iPad and crash.
geposted Mon 31 Mar 14 @ 10:03 am
geposted Mon 31 Mar 14 @ 12:11 pm
MagicMoments,
I have never experienced one crash with VDJ on Mac since I switched to Mac in 2011. Before that I ran VDJ on PC, and since 2001 I have only experienced 3 crashes, and none since ver 6 of VDJ. I run music video, live camera, music, ambient videos, clipbank. Can you give us more info on your Mac? Which Mac are you running (ie. MacBookPro 8,2) what OSX you are running (ie 10.9.1), what other software do you have open at the same time, and what hardware you might have connected (ie controller, sound card, external video adapter)? Is your media internal, or are you using an external drive?
geposted Thu 03 Apr 14 @ 7:07 am
these are known crashes. VDJ is well aware of how the software will crash on a mac.
If I told you the steps to take, you too will get a crash.
I am not worried, waiting patiently for the next version. No sense in fixing VDJ 7 now when we are days away from VDJ8.
Scott
geposted Thu 03 Apr 14 @ 7:52 am
Hi
I had many crashes on my MacBook Unibody ( Alu, and no Pro ) 13" 5,1 since OSX 10.9 Mavericks and 8GB Performance.
There are Crash Reports.
With 10.7, and 10.8 the system was perfect, and I hab no crash.
Now its not perfect fpr working.
Greetings
Chris
geposted Fri 04 Apr 14 @ 8:37 am
Great to hear, however, there are known crashes that happen every time on a Mac.
They are fixing them for VDJ8, I am sure.
Not worried one but. I know how to avoid them and I am confident that things will get fixed very soon.
geposted Fri 04 Apr 14 @ 10:14 am
can you recreate the crash?
geposted Fri 04 Apr 14 @ 5:09 pm
Sorry, not gonna repeat it again.
Please read the thread.
geposted Fri 04 Apr 14 @ 6:00 pm
